3750 - access lists on vlan interface
Cpartner1
I have a small question concerning in and out traffic direction on vlan interfaces, in combination with access lists
We have an 3845 integrated services router that has a network module installed
Specs of the network module
NME-XD-48ES-2S-P   12.2(35)SE5             C3750-IPBASE-M
On the network module I have created two vlans with a vlan interface for each vlan
vlan 500
name DEMO
vlan 516
name EDUCATION
interface Vlan500
ip address 10.5.0.1 255.255.240.0
interface Vlan516
ip address 10.5.16.1 255.255.240.0
I want to permit traffic from demo to education (and returning traffic) but i want to deny traffic originating from education to demo
What is the best way to implement this ?
Second question is regarding traffic direction
Suppose traffic is coming from education and going to demo
Once the traffic has been routed on the switch from the eduction vlan interface and arrives at the demo vlan interface
Is this traffic going out of the demo interface or coming in on the demo interface (with access lists in mind)
Do I need to define this to apply an access list to that traffic ?
SW01(config)#interface vlan500
SW01(config-if)#ip acc
SW01(config-if)#ip acces
SW01(config-if)#ip access-group MYLIST out
Or do I need to define this to apply an access list to that traffic ?
BEVILro02-SW01(config)#interface vlan500
BEVILro02-SW01(config-if)#ip acc
BEVILro02-SW01(config-if)#ip acces
BEVILro02-SW01(config-if)#ip access-group MYLIST in
Or maybe both or possible ?
Thanks in advance !
Kind Regards
Stijn
gaysunda
Hi Stijn,
interface Vlan500
interface  Vlan516
To allow traffic from demo to education (and returning traffic) but   deny traffic originating from education to demo
we carete an Access-list and add the established keyword at the end of  the permit statement. This would allow only traffic orignated from demo back and  forth but deny any other traffic, but this would work for TCP protocol only. It  indicates an established connection. A match occurs if the TCP datagram has the  ACK or RST bit set. The nonmatching case is that of the initial TCP datagram to  form a connection.
ip access-list ext 123
permit tcp any any established
we apply this in the inbound direction on the Education Vlan. So all  traffic from demo would come to education , but return traffic only with ACK or  RST bit set is allowed. So no new connections from Education would be  allowed.
For the Second question:-
With respect to the access-list it would matter how we are defining the  ACL to the flow of traffic.
An ACL may be applied in either direction as long as we define the  traffic and its flow correctly.
for eg:-
if we want a certain host x.x.x.x from education vlan 516 to be blocked  from being reached by a host y.y.y.y on demo vlan 500, then we can have the acl  in two ways, applied on that Vlan 500 interface
x.x.x.x-- 516---switch---500---y.y.y.y
deny ip host y.y.y.y host x.x.x.x
this would have to be applied  in the inbound direction as the traffic  hitting vlan 500 would have source ip of y.y.y.y and dest ip of x.x.x.x
if we were to configure it this way
deny ip  host x.x.x.x host y.y.y.y
then it would have to be applied in the out bound direction as it would be  leaving the router with a source ip of x.x.x.x to reach y.y.y.y on vlan  500
hope this helps
Gayathri
Please rate if this answered your question
