3750 - CPU high utilization - Adjust Regions
alireza1368m
hi all
we have one WS-C3750G-48TS with (C3750-ADVIPSERVICESK9-M), Version 12.2(46)SE
anyone know about "Adjust Regions " ?
sh processes cpu sorted  | ex  0.00%
CPU utilization for five seconds: 33%/1%; one minute: 26%; five minutes: 30%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  63   635500237    918026     692253 15.97% 11.44% 13.16%   0 Adjust Regions
111       10519      3159       3329  3.35%  0.38%  0.41%   1 SSH Process
196   8246228732038455866        404  2.71%  3.85%  4.39%   0 Spanning Tree
190    82917933 227899056        363  1.11%  0.81%  0.75%   0 IP Input
  98   121771435  13095125       9299  0.63%  0.74%  0.74%   0 hpm counter proc
   9    29805794  75875748        392  0.47%  0.29%  0.29%   0 ARP Input
  94    12985165 112264535        115  0.47%  0.09%  0.06%   0 hpm main process
  62    77858557 670704376        116  0.47%  0.43%  0.38%   0 Fifo Error Detec
153    10835013  13096584        827  0.31%  0.15%  0.15%   0 PI MATM Aging Pr
141    51182572   2706884      18908  0.31%  0.35%  0.34%   0 HQM Stack Proces
133    80707174 376158730        214  0.31%  0.32%  0.40%   0 Hulc LED Process
134     7274727  19376740        375  0.15%  0.06%  0.05%   0 HL3U bkgrd proce
  35     6898114  13119026        525  0.15%  0.03%  0.02%   0 Per-Second Jobs
177     8387009 122559544         68  0.15%  0.11%  0.10%   0 IPe BSSM Manager
241     9370849   3949000       2372  0.15%  0.06%  0.05%   0 IP RIB Update
142     4409697   5413747        814  0.15%  0.04%  0.01%   0 HRPC qos request
  sh processes cpu sorted | exclude 00
CPU utilization for five seconds: 67%/19%; one minute: 57%; five minutes: 56%
  63   636260694    919026     692502 30.99% 19.77% 17.52%   0 Adjust Regions
196   8248656572038667916        404  3.99%  5.41%  5.42%   0 Spanning Tree
  62    77898147 670851412        116  1.43%  1.20%  1.28%   0 Fifo Error Detec
133    80747523 376243553        214  1.11%  1.28%  1.36%   0 Hulc LED Process
190    82952027 227966823        363  0.95%  0.86%  0.91%   0 IP Input
   9    29820744  75902508        392  0.79%  0.38%  0.38%   0 ARP Input
  98   121806955  13098246       9299  0.47%  0.75%  0.79%   0 hpm counter proc
  59    64087029 325853323        196  0.47%  1.04%  1.09%   0 RedEarth Tx Mana
  94    12991662 112290226        115  0.47%  0.24%  0.21%   0 hpm main process
141    51198476   2707549      18909  0.31%  0.37%  0.37%   0 HQM Stack Proces
308     4616583  54415313         84  0.15%  0.04%  0.04%   0 EIGRP-IPv4: Hell
  76    25689445 378327551         67  0.15%  0.23%  0.22%   0 HLFM address lea
121     2868389  65069309         44  0.15%  0.24%  0.25%   0 Hulc Storm Contr
111         772       221       3493  0.15%  0.10%  0.10%   1 SSH Process
194     8746691  33688210        259  0.15%  0.15%  0.15%   0 ADJ resolve proc
134     7280879  19381254        375  0.15%  0.23%  0.19%   0 HL3U bkgrd proce
Thanks in Advance
11 Replies 11
Leo Laohoo
No but the IOS you currently are using can be potentially the cause of your high CPU.
Upgrade to  12.2(55)SE8.  This is a very stable version.
Thanks Leo
i did it, but the problem still exist
Post the output to the command "sh proc cpu | ex 0.00".
308     4616583  54415313         84  0.15%  0.04%  0.04%   0 EIGRP-IPv4: ****
I've never seen this before.  And your switch stack is running 12.2(55)SE8?
Something in your configuration is triggering "Adjust Regions".
yes i upgrade to 12.2(55)SE8 as u said
unfortunately there is no document to give me a idea about this process
I am having this same issue on a C3750X stack running 12.2(58)SE2.  One 3750X running IP services and the other base.
3750X#sh processes cpu sorted
CPU utilization for five seconds: 26%/0%; one minute: 17%; five minutes: 18%
  91    49388582      207470     238067 11.67%  7.05%  7.31%   0 Adjust Regions
  10     1239236       11142     111222  2.07%  0.25%  0.17%   0 Licensing Auto
U
  85     8246762     2469762       3339  1.43%  1.37%  1.19%   0 RedEarth Tx Man
a
389        3751         236      15894  1.11%  0.11%  0.26%   1 Virtual Exec
Did you get this resolved by any chance?  I have only have 1 other 3750X stack running the same ver and i dont have this problem there.
I have the same problem but i think its related to an acl and route-map config. going to remove it in the next week and I will let you know how it goes
Sorry wrong post
Kind Regards
Paul
did you had some command on your running-config like
access-list hardware region
let us know.
had a great day . best regards, and rate if you'll find this post useful
Just went through the configs and I do not.  Installed another 3750X stack with same ver and having same issue.  It must be something in the config but nothing stands out.
