10-17-2006 04:58 AM - edited 03-05-2019 12:17 PM
Hi all
RTR1-SW-RTR2 setup. I mark traffic with various IP prec and can see it leaving RTR1 interface as such. when it gets to RTR2 it is all changed to IP prec 0 which is not teh desired effect. I ghave no policy maps inbound in my RTR2.
My suspect is SW, where mls QOS is disabled...so all shoudl be pass thru. I can see pcakets comimg as various IP prec but exiting to RTR2 as routine traffic. my SW ports are not configured with override.
any thoughts on this might be ?
TIA
Sam
10-17-2006 05:20 AM
Hi Sam,
Can you please post the "sh run" from the switch?
Ankur
10-17-2006 05:40 AM
Hi Ankur
I have snipped what si not needed.
hostname SW01
switch 1 provision ws-c3750g-12s-d
vtp domain ESW
vtp mode transparent
udld enable
ip subnet-zero
no ip source-route
ip domain-name msn.sonofon.dk
ip name-server 172.17.30.21
spanning-tree mode mst
spanning-tree mst configuration
name ROC
revision 5
instance 1 vlan 1-10, 12, 22-99, 102-500, 900-998
instance 2 vlan 11, 13-21, 100-101, 501-899, 999
vlan internal allocation policy ascending
vlan 405
name [CUSTOMERXXX]
interface GigabitEthernet1/0/1
description [RTR01]
switchport mode trunk
switchport nonegotiate
load-interval 30
speed nonegotiate
interface GigabitEthernet1/0/10
description [RTR02]
switchport trunk allowed vlan 405
logging event trunk-status
logging event spanning-tree
load-interval 30
duplex full
speed 100
10-17-2006 05:59 AM
Hi Sam,
Is it possible for you to sniff gig1/0/10 interface?
Ankur
10-17-2006 09:32 AM
Hi Ankur
I am unable to sniff, but I can look at stats on mls QOS interface. I see all packets under when heading IP prec 0-4.
I will add an output when back at my desk.
Thanks again
Sam
10-17-2006 06:16 AM
i think the prec values are getting overwritten
Can you try trusting the trunk ports
mls qos
mls qos trust cos
Narayan
10-17-2006 09:36 AM
Hi Narayan
yes I agree they are overwritten...but why?
the switch is configured with no QOS and should be a plain passthru.
I will upgrade IOS just in case, and BTW it is Enhanced image I am running.
Sam
