3750-E and stackwiseplus
fropert
Community Member
Show command output 32GB on stackwiseplus. Shouldn't be 64GB ? Show command bug ? Did I need to enable stuff to get 64GB ?
I have stack of five 3750E switches members.
sh switch stack-ring speed
Stack Ring Speed : 32G
Stack Ring Configuration: Full
Stack Ring Protocol : StackWisePlus
sh ver :
Cisco IOS Software, C3750E Software (C3750E-UNIVERSAL-M), Version 12.2(35)SE5, R
ELEASE SOFTWARE (fc1)
Cheers,
Mark Yeates
Level 11
Level 11
Francois,
Are you using the all of the stackwise ports for complete redundancy within the stack? Please see figure 3 in the white paper.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/prod_white_paper09186a00801b096a.html
HTH,
Mark
Joseph W. Doherty
Not certain, but perhaps you are already getting full speed. You might be bumping into a technical stat that doesn't correspond with marketing hype.
64 GB on StackWisePlus, means what, exactly? What StackWisePlus provides is two 16 Gbps, full duplex stack ports.
Not intended as a negative, if you work for Cisco(?), I'm surprised you need to post to the public support forums to answer a question on a Cisco product.
