3750 E and X wont stack.
Anders Palmgren
Im wondering if anyone can see if I did any fault or if I just missed something.
Im trying to stack 2 3750E-24PD-S and 2 3750X-12S-S. The 2 3750E finds eachother and stacks with one master as they should. The problem is that and the 3750X does the exact same thing instead of joining the 3750E stack.
Both runs the same IOS (c3750e-ipbasek9-mz.122-58.SE2).
The stackingcables are connected like following atm (I tried booting up the switches one at a time and all at once, no difference in the result):
3750E 1 4
3750E 1 2
3750X 2 3
3750X 3 4
I have also tried with:
3750E 4 1
3750E 1 2
3750X 2 3
3750X 3 4
3750E 1 4
3750E 2 1
3750X 3 2
3750X 4 3
I read the following links and some forums and (as much as I can see) everything is correctly configured and connected. But since it still wont work Im wondering what I am missing.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/prod_white_paper09186a00801b096a.html
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/troubleshooting/switch_stacks.html
Would be grateful for any tips or hints that I can try to get them working as one stack.
Cheers,
Anders
8 Replies 8
hobbe
Level 7
Level 7
First of all what does your logs tell you ?
are the cables correctly connected in the back of them ?
if all things else is correct I think there is a thing with the SDM template in the 12S switches.
I have not personally come across this.
but i think i have seen somewhere that you need to change the SDM template for the 12S switches to the same as the 3750E switches. since the 12s has a template that no other 3750 switch has.
Good luck
Leo Laohoo
If you want it done right, it's got to be stacked like this:
3750E      1      2
3750E      2      3
3750X      3      4
3750X      4      1
Next, let's say you want the 3750E to be master, right?  Ok, power down the two 3750X, attach the stacking cable and then power up the 3750X one-at-a-time and in-the-order-of-your-stack.
Before the power up, console into the 3750E and the 3750X and post the entire bootup process of the 3750X and the stack joining process from the 3750E master.
Anders Palmgren
I changed back the stacking cables to the setting that leolaohoo said.
Then I checked logs etc.
SDM looks to be the same.
But what Ive found is 2 things.
  • 1 I have a major version missmatch, even though I run the same ios image (read that if I have the same ios image this shouldnt be an issue). However the X series using 6.46 and the E series using 1.46.
  • 2 Could this be an an issue. The license level. Both 3750 are bought with IPbase license. But when I run the commands sh ver and sh license all on the 2 I get the following:
  • the E series:
    License Level: ipbase
    License Type: Permanent
    Next reload license Level: ipbase
    License Store: Primary License Storage
    StoreIndex: 0   Feature: ipbase                            Version: 1.0
            License State: Active, In Use
            License Priority: Medium
            License Count: Non-Counted
  • the X series:
    License Level:
    License Type: Default. No valid license found.
            License State: Active, Not in Use
If you have a version mismatch, please post the output to the "sh version" to all the switches individually.
3750X-Catalysts:
Switch# sh ver
Cisco IOS Software, C3750E Software (C3750E-IPBASEK9-M), Version 12.2(58)SE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 01:23 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE, RELEASE SOFTWARE (fc1)
Switch uptime is 21 minutes
System image file is "flash:c3750e-ipbasek9-mz.122-58.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level:
cisco WS-C3750X-12S (PowerPC405) processor (revision A0) with 524288K bytes of memory.
Processor board ID FDO1543Z11V
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
32 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 64:9E:F3:8B:A9:80
Motherboard assembly number     : 73-13329-03
Motherboard serial number       : FDO15430QYH
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-C3750X-12S-S
Daughterboard assembly number   : 800-32727-02
Daughterboard serial number     : FDO15421WYQ
System serial number            : FDO1543Z11V
Top Assembly Part Number        : 800-35090-01
Top Assembly Revision Number    : B0
Version ID                      : V01
CLEI Code Number                : CMMFG00ARA
Hardware Board Revision Number  : 0x04
Switch Ports Model              SW Version            SW Image
     1 18    WS-C3750X-12S      12.2(58)SE2           C3750E-IPBASEK9-M
*    2 18    WS-C3750X-12S      12.2(58)SE2           C3750E-IPBASEK9-M
Switch 01
Switch Uptime                   : 21 minutes
Base ethernet MAC Address       : 64:9E:F3:9A:1F:80
Motherboard serial number       : FDO15440PGT
Daughterboard serial number     : FDO15421X8N
System serial number            : FDO1544Z091
Top assembly part number        : 800-35090-01
Top assembly revision number    : B0
Version ID                      : V01
License Type                    : Default. No valid license found.
3750E-Catalysts:
STO-R010#sh ver
BOOTLDR: C3750E Boot Loader (C3750E-HBOOT-M) Version 12.2(44r)SE3, RELEASE SOFTWARE (fc3)
STO-R010 uptime is 34 minutes
export@cisco.com.
cisco WS-C3750E-24PD (PowerPC405) processor (revision M0) with 262144K bytes of memory.
Processor board ID FDO1512Y0YY
2 Virtual Ethernet interfaces
56 Gigabit Ethernet interfaces
Base ethernet MAC Address       : E8:40:40:D2:36:00
Motherboard assembly number     : 73-11176-14
Motherboard serial number       : FDO15121UW8
Model revision number           : M0
Motherboard revision number     : B0
Model number                    : WS-C3750E-24PD-S
Daughterboard assembly number   : 800-29737-01
Daughterboard serial number     : FDO151211JK
System serial number            : FDO1512Y0YY
Top Assembly Part Number        : 800-28922-04
Version ID                      : V05
CLEI Code Number                : COMCE00ARB
Hardware Board Revision Number  : 0x00
*    1 30    WS-C3750E-24PD     12.2(58)SE2           C3750E-IPBASEK9-M
     2 30    WS-C3750E-24PD     12.2(58)SE2           C3750E-IPBASEK9-M
Switch 02
Switch Uptime                   : 34 minutes
Base ethernet MAC Address       : A4:56:30:1C:F3:80
Motherboard serial number       : FDO1603050K
Daughterboard serial number     : FDO16020E2X
System serial number            : FDO1603Y162
Top assembly part number        : 800-28922-04
Top assembly revision number    : C0
Version ID                      : V05
License Level                   : ipbase
License Type                    : Permanent
Next reboot licensing Level     : ipbase
Looks fine to me.  Both 3750E and 3750X are running the same IOS and feature set.
The global stack cabling has been validated, the sdm (show sdm prefer) is the same, the IOS as well 12.2(58)SE2.
However there is a condition when mixing stacks (in this case 3750-X with 3750-E correspond to mixed hardware stack)
=> From the documentation
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_58_se/configuration/guide/swstack.html#wp1307692
Mixed stacks are not supported with switches running the LAN base feature set.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6406/data_sheet_c78-584733.html
The Cisco Catalyst 3750-X Series Switches with LAN Base feature set can only stack with other Cisco Catalyst 3750-X Series LAN Base switches.
A mixed stack of LAN Base switch with IP Base or IP Services features set is not supported.
Also, when looking at the show license output for the 3750X, ipbase feature is Active but not in use.
& License Type                    : Default. No valid license found.
================================================== (show license all may show the lanbase is in fact in use).
Although the 3750-X have the ipbase license Active (but not in Use), it explains why we notice a major version mismatch (6.46 for the X corresponds to lanbase – 1.46 for the E for ipbase). Thus the 3750X stacks only together (consequently E stack together).
Can you try to issue on both 3750X the command license boot level ipbase , save the config, reload the switches and test again ?
Best regards.
Karim
Thanks all for the help.
Apparently I had to use the universal ios image to get the ipbase license valid and in use on the 3750X series. Using the ipbase ios image didnt work.
On the 3750E it didnt matter if I used the universal or ipbase, it is valid as ipbase regardless.
I also heard that Cisco wants to use the Universal image for all 3750's and that the 3750E maybe wasnt inline just yet, and that was why the ipbase worked on that series.
This is what our technical support that is a cisco partner told me anyway.
However now everything stacks and works perfect
Again thanks for the help.
