3750-E - hardware not supported by firmware
pfillips11
Hello, I have got new 3750 e-series which has universal image installed on it. I need to put this switch in stackwise with non-e-series 3750. The problem is that non-e-series are running IP BASE IOS and I wanted to put the same IOS on 3750 e-series. But it gives me the following message when I try to boot the switch with c3750-ipbase-mz.122-35.SE5.bin image.
Error: hardware not supported by firmware.
       Try loading newer software instead.
       System Resetting...
Thank you!
Ganesh Hariharan
       System Resetting...
Thank you!
Catalyst 3750-E switches running Cisco IOS Release 12.2(35)SE2 are compatible with Catalyst*3750 switches and Cisco EtherSwitch service modules running Cisco IOS Release*12.2(35)SE. Catalyst 3750-E switches, Catalyst 3750 switches, and Cisco EtherSwitch service modules can be in the same switch stack. In this switch stack, we recommend that the Catalyst*3750-E switch be the stack master.
Check out the below link for more information
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750e_3560e/software/release/12.2_35_se2/release/notes/OL9778.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Leo Laohoo
It won't work and that's not how it's done.
For the 3750/3750E/3750X stackwise to work, you have to follow the simple rule:  Same IOS version and same Feature Set.
So if your 3750E is running Universal, what is the feature set?  IP Base?  IP Services?  You can determine this by using the command "sh version" or "sh license".  Then you have to make sure your 3750 runs the same feature set.
I get why it doesn't work.  How do I fix it?
