3750 errdisable
glenda.clark
Community Member
show ip inter brief
displays ports with errdisable
how do I remove the notice errdisable from interface?
Jerry Ye
Hi Glenda,
You can clear it by shutdown, no shutdown an interface:
interface x/x
shutdown
no shutdown
HTH,
jerry
Leo Laohoo
Hi Glenda,
Jerry's response is the way to enable the port. But I would like to question WHY did the port go into error disable. If you have not yet enabled the port, try the command "sh interface status err" will let users know the cause/reason.
Hope this helps.
#show logg
Ordinarily, you can find the answer.
