12-04-2013 12:17 PM - edited 03-07-2019 04:55 PM
I have a 3845 router with two 3750 etherswitch modules installed. One of the switch modules has no IOS so it's stuck at the switch: prompt. Anyone know where I can find any documentation on the commands that are available to me? For instance,
switch: help boot
Usage for "boot" is:
boot [-n|-j] [-p] [-c] [-f] [-i] [-m] [-notnd] [-notni] [-post] [-skip_post] [-reserve_mem <1-15>] [-no_esp_keepalive] [<filename>]
Also, can I boot this or download an image from a tftp server? I've used the set command to set the IP, gateway, tftp server etc... but then what? There's no tftpdnld command.
Thanks in advance....
12-04-2013 01:41 PM
12-05-2013 06:10 AM
Thanks. I've read that but it didn't answer my question about documentation on the commands that are available at the switch: prompt. Also, the 3750 Etherswitch has no console port. How would I xmodem the IOS to the switch using the router console port?
12-05-2013 02:16 PM
