3750 flash
glen.grant
Question if you have an image in a directory that isn't being used is it ok to delete the directory to free up space to add a new image ? It is currently using another image that is not in a directory . I know I have done this on 2950 but just want to verify before deleting the directory .
Glen,
I don't see why not? You would have to delete the files in the directory before removing the directory itself. Have a look at this link..
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_command_reference_chapter09186a00805a743a.html#wp1004588
Sundar
Normally you can delete the directory with one command del flash: /force /recursive .
