3750 inter-vlan routing
matt_heff
does the ip-base image do inter-vlan routing, or do i need the ip-services image?
jcorrale
Hi Matt,
I checked on Cisco Feature Navigator tool and found that IEEE 802.1Q VLAN Trunking feature is supported with IP BASE in your 3750 switch.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Here is a good document about inter-vlan routing:
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008015f17a.shtml
Hope it helps!
Juan
Collin Clark
IP base supports static routing, RIPv1 and RIPv2. Any other routing protocol requires IP Services.
HTH and please rate.
desai.jaideep
Level 5
Level 5
Sure they will do.
Just make sure to give "ip routing" and ip address to all vlans.
JD
trond-hp
IP-base support RIP og static routing.
