3750 Mixed Stack (3750G-12S and 3750E-24TD-S) Firmware
thomas.bayer
Hi guys,
I have a stack with those 3750 switches.
3750E-24TD-S is running the universal c3750e-universalk9-mz.122-35.SE9.bin
3750G-12S is running the IPbase c3750-ipbasek9-mz.122-35.SE9.bin
As I want to add another 3750G-12S, that is already running c3750e-universalk9-mz.122-55.SE9.bin,
to the stack I would like to upgrade the firmware on the existing switches.
I can't download the new universal IOS because I have not warranty contract.
Can I use the ipbase? What is the difference?
Regarding features we use only IPbase, we don't have OSPF and those features.
Many thanks!
The switch will come alive and will receive the Cisco IOS version from the master, when that is completed it will be ready to service network requests.
Nope, not going to work.  Make sure the new switch has the same IOS level as the rest of the stack.
9 Replies 9
Leo Laohoo
3750E won't run to that level of code, 12.2(35)SE.
Here's the thing, the IOS of the 3750G-12, which is 12.2(55)SE9, can be transfered to the non-"E".  You can just copy the BIN file and copy it across.  Your challenge will be to get the 12.2(55)SE9 IOS for the 3750E.
Hi Leo,
I can download this for the 3750E:
Description:IP BASE
Release:12.2.55-SE9
Release Date:18/Mar/2014
File Name:c3750e-ipbasek9-mz.122-55.SE9.bin
Min Memory:DRAM 256 MB Flash 64 MB
Size:13.93 MB (14605339 bytes)
MD5 Checksum:
eaab9937a43d7c95fc60a708448172bc
and for the 3750G:
Description:IP BASE
Release:12.2.55-SE9
File Name:c3750-ipbasek9-mz.122-55.SE9.bin
Min Memory:DRAM 128 MB Flash 16 MB
Size:11.55 MB (12106358 bytes)
MD5 Checksum:
6a75321f283a12545c83d7799b6ee283
Do you think that will work?
Thanks!
Will it work will depend on the license level of the 3750E.  If the license is IP Base then it will work.
ok, understood.
So how about this procedure - I don't touch the existing stack firmware and run those commands on the new stack member:
switch 3 provision 3750G-12S
>Power off the new stack member
>Connect the new member to the Cisco stack using the stacking cables, 1 loop at a time.
>Power on the new stack member. The switch will come alive and will receive the Cisco IOS version from the master, when that is completed it will be ready to service network requests.
That should work fine, right?
Please excuse my lack of knowledge on Cisco.
Hi Leo,
another question please. My stack looks currently like this:
Switch Ports Model              SW Version            SW Image
1 30    WS-C3750E-24TD     12.2(53)SE            C3750E-UNIVERSAL-M
2 12    WS-C3750G-12S       12.2(53)SE            C3750-IPBASE-M
Now I got a new stack member - 3750X
(running c3750e-universalk9-mz.150-2.SE5).
As far as I found out I can`t use 12.2(53) on the 3750X, but 12.2(55) would work.
So I downgraded the 3750X to:
c3750e-ipbasek9-mz.122-55.SE5.bin
The next step would be to upgrade the existing 3750G and 3750E.
For the 3750G I would use this:
c3750-ipbasek9-mz.122-55.SE5.bin
For the 3750E I would use this:
After that I should be able to stack them together right?
Will there be any problem when I switch from universal to ipbase on the 3750E?
Many thanks!
12.2(55)SE5 isn't a very stable IOS.  For a 3750-series family, I'd recommend 12.2(55)SE9.
This will depend on your license.  If your 3750X has a license level of IP Base, then the 3750X universal license can stack nicely with IP Base.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You're sure the "new" unit is another 3750G-12S? If so, I'm surprised it's running a 3750E image.
If you have another 3750G-12S with 35SE9, you should be able to copy the image from it to the "new" 3750G-12S.  (Legally, I believe you're allowed to downgrade the IOS version as long as you don't upgrade the IOS feature set.)
tanner.zaitt
Level 3
Level 3
Hello all,
I am in the same situation and I could share my experience in this case.
* 2 12 WS-C3750G-12S 12.2(50)SE5 C3750-IPBASEK9-M
* 2 30 WS-C3750E-24TD 12.2(50)SE5 C3750E-UNIVERSALK9-M
In this combination with image 12.2(50)SE5 they are stacked successfully!
Please keep in mind that one image is UNIVERSALK9-M and other image is IPBASEK9-M.
I have other question are these models affected by Memory Component Issue - Cisco ?
I am not able to check with my account.
