3750 MLS to 3850 MQC Conversion of QoS Configuration
DamienTokyo
Hi everyone,
I am sorry to bother you with this matter but I am struggling to adapt one part inside the QoS configuration
I had on a Catalyst WS-C3750X-48 (version 15.2(4)E9) to a new switch 3850X-48 (version 16.12.05b)
I have been able to translate the class-map, policy-map and queue-set. However for below part I am stuck.
Here is what I had inside the old config:
mls qos queue-set output 2 threshold 1 100 100 100 400
mls qos queue-set output 2 threshold 2 200 200 100 400
mls qos queue-set output 2 threshold 3 100 100 20 400
mls qos queue-set output 2 threshold 4 100 100 100 400
According to below Cisco configuration:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3850-series-switches/118629-technote-qos-00.html#anc41
Example 10
We should get something like this on 3850 (off course by changing numbers inside):
queue-limit cos  2 percent 50
queue-limit cos 3 percent 50
queue-limit cos 6 percent 70
queue-limit cos 7 percent 70
but I am completely lost on how I can translate threshold I had previously to something similar into the new syntax. Cisco documentation is not very clear to me on how to adapt queues and buffers policy to 3850.
Is the logic different, with calculation or else to do ?
Has someone any idea about this ?
Best regards,
Damien
tough one, this has come up quite a bit in the past. There is not really a 1 to 1 conversion as far as I recall. It is mostly class-based, and you need to decide which traffic you want to prioritize, and assign that traffic to classes...
Joseph W. Doherty
The 3850's QoS architecture is both similar and in some ways "improved/better" than the 3750's.
As, at least in my approach, platform QoS implementations are often just a "subset" of what my logical QoS model/policy is.  For any new or different platform, rather than just trying to "replicate" one platform's QoS implementation to another (different) platform, I try to get the new/different platform to best implement my logical QoS model/policy.
Might this be possible for you too?
One reason I ask, you seem to be asking (mostly) about replication of WTD, which, can be a bit more advanced part of a QoS model/policy.  If you don't really have your own logical QoS model/policy dealing with WTD, and/or early dropping, you might be better off just using the 3850's defaults or set WTD to all be max.
I have used enabling Auto QoS on a single port on a new platform to get some of the basic stuff created. If the values from Auto QoS meet your needs, great! If not, you can use the platform specific entries created by Auto QoS as a template.
DamienTokyo
Hi everyone, sorry for late reply but thanks for your answers.
After all I have just created class-map for my target traffic and used Cisco auto-QoS inside Policy-maps.
Therefore I didn't try to convert from 3750 syntax since the way of managing QoS is slightly different, I let auto-QoS doing its business with the priorities, thresholds, etc. Once class-map and policy maps are defined, config is very simple following Cisco docs.
To be honest I have kind of given up on trying to understand how the previous QoS management was working and if my new settings will be correct. I will confirm when equipment will come on production.
I would say to people that have same question as me:
Just start your QoS setting/management from zero using Cisco Auto-QoS  and tune it (if needed) using Cisco Docs
