3750 model differences
andrewgrieve
Community Member
Would someone be able to give me a quick rundown of the differences between the different 3750 models (vanilla/v2/e/x)? I'm having trouble getting anything useful from the product pages. Are the more recent ones going to replace the vanilla version, or do they just have extra features?
Cheers
Jon Marshall
Andrew
The Q&A's are quite good for this.
Main differences between 3750 and 3750-E
Switch Architecture
Q. What are the notable differences/features between the Cisco Catalyst 3750-E and the Cisco Catalyst 3750?
A. The differences are as follows:
• Cisco Catalyst 3750-E provides a true line-rate (nonblocking) Gigabit Ethernet to the desktop solution with two line-rate 10 Gigabit Ethernet uplinks.
• The Cisco Catalyst 3750-E is a stackable switch, and it is backward compatible and stacks with the existing Cisco Catalyst 3750 family switches.
• The Cisco Catalyst 3750-E has a backplane switching ASIC, which also makes forwarding decisions, to help the switch perform wire-rate local switching.
• The Cisco Catalyst 3750-E supports dynamic a pluggable module that converts a 10 Gigabit Ethernet slot into a slot that can fit 2 Gigabit Ethernet ports. This allows for easy migration for customers moving from Gigabit Ethernet uplinks to 10 Gigabit Ethernet uplinks.
• The Cisco Catalyst 3750-E supports hot-swappable power supplies.
• The Cisco Catalyst 3750-E supports jumbo frame routing and increases the frame size to 9216 bytes.
• The Cisco Catalyst 3750-E supports uncompressed IPv6 address tables. This allows the software to program the full IPv6 address in the hardware. In addition, equal cost routing for IPv6 uses the uncompressed IPv6 address.
• The Cisco Catalyst 3750-E supports destination stripping of unicast packets.
Main differences between 3750-E and 3750-X
Q. What are the differences between the Cisco Catalyst 3750-X and 3560-X and the rest of the Catalyst 3000 switches?
A. The Catalyst 3750-X and 3560-X are line rate nonblocking switches that are identical to the Catalyst 3750-E and 3560-E Series with the following added features:
• Cisco StackPower technology: Aggregates and shares power supplies in a stack and supports a zero-footprint redundant power supply
• Network modules: Field-replaceable uplink, 1 Gigabit and 10 Gigabit versions
• Full 802.3at PoE+: Supports 30W per port on all 48 ports in a single RU switch
• Three software feature sets: LAN Base, IP Base, and IP Services
• Dual redundant power supplies and fans: Four power supply options, including a DC power supply for PoE
• MACsec: Hardware-based encryption (802.1ae). Includes MACsec Key Agreement (MKA) (included in Dot1X-rev)
As for EoS/EoL, if you go to the product page for each switch there will be a link to any EoS/EoL announcements made among the links for datasheets etc.
Jon
Jon Marshall
Andrew
Switch Architecture
Jon
Ah that makes much more sense now, thanks very much
