Netflow issue
alioune-ndiaye
Level 2
Level 2
Hi everybody,
I need help regarding Netflow
I have this message in log file:
%EARL_NETFLOW-SP-4-TCAM_THRLD: Netflow TCAM threshold exceeded, TCAM Utilization [97%]
I know that indicates the TCAM is almost full.
I use sup 720 with PFC3BX
I wanted to disable completely  the Netflow by
no mls flow ip
Result: I still got the same log message above, however I find  no mls flow ip in the running configuration file.
Any help to fix the issue would be appreciated.
regards
Alioune
jacyu2
Hi Alioune,
You could try "no mls netflow".
Jack
jacyu2
Hi Alioune,
Jack
alioune-ndiaye
Level 2
Level 2
Thank  you Jack, indeed the no mls netflow command  fine.
I no more get the log messages.
I have one question what command disable the Netflow?
I tried no mls  netflow ip , but it was not  disable it.
thank you.
Alioune
