3750 not passing traffic between L3 ports...weird
chrisserafin
Even when I'm on the switch I cannot ping the FW from the far interface on the switch:
xxxx-02#ping 10.63.7.6 source 10.63.7.2
Sending 5, 100-byte ICMP Echos to 10.63.7.6, timeout is 2 seconds:
Packet sent with a source address of 10.63.7.2
Success rate is 0 percent (0/5)
xxxx-02#ping 10.63.7.6 source 10.63.7.5
Packet sent with a source address of 10.63.7.5
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/8 ms
xxxx-02#sh ip int brie
Vlan1 unassigned YES NVRAM administratively down down
Vlan10 10.63.0.1 YES NVRAM up up
Vlan101 unassigned YES NVRAM down down
Vlan102 10.63.2.1 YES NVRAM up down
Vlan103 10.63.3.1 YES NVRAM up down
Vlan104 10.63.4.1 YES NVRAM up down
Vlan105 10.63.5.1 YES NVRAM up up
Vlan106 10.63.6.1 YES NVRAM up up
Vlan107 unassigned YES NVRAM down down
FastEthernet0 unassigned YES NVRAM administratively down down
GigabitEthernet1/0/1 10.63.7.2 YES NVRAM up up
GigabitEthernet1/0/2 10.63.7.5 YES NVRAM up up
Here is the switch side:
interface GigabitEthernet1/0/1
description UPLINK BowlingGreen-3845 gi0/0
no switchport
ip address 10.63.7.2 255.255.255.252
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
spanning-tree portfast
interface GigabitEthernet1/0/2
no switchport
ip address 10.63.7.5 255.255.255.252
queue-set 2
priority-queue out
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
service-policy input AutoQoS-Police-CiscoPhone
ip routing
ip route 0.0.0.0 0.0.0.0 10.63.7.6
ip route 10.0.0.0 255.0.0.0 10.63.7.1
ip route 10.63.4.192 255.255.255.192 10.63.7.6
ip route 10.254.254.0 255.255.255.0 10.63.7.6
ideas?
5 Replies 5
Jon Marshall
Apologies for asking the obvious but does the FW have a route back to 10.63.7.0/30 subnet ?
Jon
Another obvious one to watch for, does the FW allow ICMP ?
Sam
I'm guessing it does as he can ping the FW from the .5 address :-)
Jon
Good point Jon !
I would still still take a look at FW policies...I have wasted valuable time once assuming if it works for one host it would for whole subnet :-)
Same thing goes for routing from FW.
Sam
Sam
I totally agree, i was just having a bit of fun :-), no offence intended.
I have also spent many fruitless hours troubleshooting routing, vlans etc.. only to find it was a stupid firewall rule !
Jon
