3750 problem with numbering
mawe008
I changed the numner on a 3750 switch from 5 to 1 and made a reload. After this if i do a "sh ?nt status" it looks OK, but if I do a "sh run" I can see both the old numbering an the new one. 2 sets of ports. Is there anyone who has experienced this problem an have a solution for this?
8 Replies 8
Anand Narayana
Level 6
Level 6
can you show the configuration of "show run" & "show interfaces"
OK, here is the config. (in the attatchment.
i am not clear with your question, explain me what exactly your facing the problem.
When i do a "sh run" i can see 2 sets of switchports. Both the old one and the new one. When i do a "sh int statu" I can only see the new number. I use the command "switch 2 renumber 1" to change the number.
upendra07
Exactly
what is your problem
juz issue "no switch 2 provision ws-c3750-48ts" ur probz will b solved, make sure that u hav restarted the switch after issuing this command.
That worked. Thank?s
