3750 stack and serial numbers
crbates
Level 5
Level 5
The problem is that CiscoWorks reports a stack of 3750s as a single switch with one S/N. I need a way to get the slave switch serial numbers out of CiscoWorks. Anyone know how?
tonusko
Go to RME (resource manager essentials), select reports, report gentrator. Under Select an Application, choose Inventory, and under Select a Report, choose Detailed Device Report. Under device selector, choose the device you want, and then click on Finish.
That should get you the information that you need.
Hope this helps.
glen.grant
Also under the netshow command section you can run a simple show version command and it will show you the serial numbers for all switches in the stack.
