3750 stack cpu issue
Dirks
Community Member
I have 4 WS-C3750-24TS-S in stack. The command "show cpu history" shows in the 72 hour table cpu load of 100% instances. However I,m monitoring the cpu load with rmon and the alarm never fires. My high level threshold is set at 60%.
I tested the rmon by setting the threshold at 5%. this works fine.
Can anyone help me with this?
Thanks in advance.
mchin345
Level 11
Level 11
RMON is disabled by default; no alarms or events are configured.
Only RMON 1 is supported on the switch.
To verify use this commands.
Switch# show interfaces interface-id transceiver detail
For further information about configuring the Rmon Alarm & Events click this link.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_25_sec/configuration/guide/swrmon.html
Dirks
Community Member
Thanks for your reply. However the rmon not working isn't the issue. When I lower my threshold rmon works fine. The real issue is the high cpu load in the "72 hour"table on my 3750 stack and rmon doiing nothing with it.
mbroberson1
Level 7
Level 7
This will sound crazy, but I have seen issues where a bad conector cable has caused VERY high CPU utilization rates.
HTH,
Brandon
Hi Brandon. It doesn't sound crazy to me. I will check the cabling.
Thnx
