3750 Stack port issue
snallncmec
Community Member
I am provisioning a new 3750 switch stack (ip x.x.x.200) to replace an old stack (ip x.x.x.100).  I'm having issues with the stack-ports on the new stack.  Both stacks are 3750-E 48 ports (all switches in each stack are the same hardware running the same IOS code).  My SNMP monitoring is showing stack ports 1-2 and 2-1 as down, so I'm investigating.  Below (at the bottom..."SHOW OUTPUT") you find the output from the commands "show switch stack-ports summary", "show switch", and "show version".  I've tried disabling and reenabling the stack ports with:
switch 1 stack port 2 disable
switch 2 stack port 1 disable
switch 1 stack port 2 enable
switch 2 stack port 1 enable
but (with console logging) I get the following:
000138: *Mar  1 08:17:14.052 EST: % Disabling stack port not allowed with current stack configuration.
000139: *Mar  1 08:17:34.150 EST: % Disabling stack port not allowed with current stack configuration.
I've also tried reseating the stacking cable between 1-2 and 2-1 and even replacing it with a brand new stacking cable entirely, but get the same switch stack-ports summary.  It seems the problem is with port 2-1, but I can't find the stack-port summary trouble shooting for the combination of output shown (link OK = NO, Link Active = NO, but Sync OK = Yes).  It looks like both 2-1 and 1-2 are SENDING valid stacking protocol messages (Sync OK = Yes), but for some reason 2-1 is not receiving valid messages (LinkOK = No).  See "http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/software/release/12.2_55_se/configuration/guide/swstack.html#wp1277038"
So I'm stumped!  How can I get both stacking links working properly?
Sue
<<<<<<<<<<<<<<<<< SHOW OUTPUT >>>>>>>>>>>>>>>>>>>>
ServTierSw1#show switch stack-ports summary
Switch#/  Stack   Neighbor   Cable    Link   Link   Sync      #          In
Port#      Port                  Length    OK   Active   OK    Changes    Loopback
               Status                                                         To LinkOK
  1/1        OK         2          50 cm     Yes   Yes    Yes        2          No
  1/2        Down      None    50 cm     Yes    No     Yes       26         No
  2/1        Down      None    50 cm     No     No     Yes       24         No
  2/2        OK         1          50 cm     Yes   Yes    Yes        2         No
Switch/Stack Mac Address : a8b1.d4e5.6980
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master a8b1.d4e5.6980     15     1       Ready
2       Member a8b1.d4e5.7200     10     1       Ready
ServTierSw1#show ver
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 02-Dec-10 06:08 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750E-HBOOT-M) Version 12.2(44r)SE3, RELEASE SOFTWARE (fc3)
ncmec-ServTierSw1 uptime is 13 hours, 30 minutes
System image file is "flash:c3750e-universalk9-mz.122-55.SE1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750E-48TD (PowerPC405) processor (revision K0) with 262144K bytes of memory.
Processor board ID FDO1424Z042
Last reset from power-on
3 Virtual Ethernet interfaces
1 FastEthernet interface
104 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : A8:B1:D4:E5:69:80
Motherboard assembly number     : 73-11175-14
Motherboard serial number       : FDO142412MU
Model revision number           : K0
Motherboard revision number     : A0
Model number                    : WS-C3750E-48TD-S
Daughterboard assembly number   : 800-29737-01
Daughterboard serial number     : FDO14240T9F
System serial number            : FDO1424Z042
Top Assembly Part Number        : 800-28920-03
Top Assembly Revision Number    : A0
Version ID                      : V04
CLEI Code Number                : COMCD00ARA
Hardware Board Revision Number  : 0x00
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3750E-48TD     12.2(55)SE1           C3750E-UNIVERSALK9-M
     2 54    WS-C3750E-48TD     12.2(55)SE1           C3750E-UNIVERSALK9-M
Switch 02
Switch Uptime                   : 13 hours, 30 minutes
Base ethernet MAC Address       : A8:B1:D4:E5:72:00
Motherboard serial number       : FDO142412LB
Daughterboard serial number     : FDO14240UHY
System serial number            : FDO1424Z05V
Top assembly part number        : 800-28920-03
Top assembly revision number    : A0
Version ID                      : V04
License Level                   : ipbase
License Type                    : Permanent
Next reboot licensing Level     : ipbase
Configuration register is 0xF
ServTierSw1#
p.mcgowan
Level 6
Level 6
it is possible you have a faulty stack port on one of the switches.
have you tried connecting stack 1/1 to stack 2/1 and 1/2 to 2/2 to see if the fault stays with port 2/1 or 1/2?
I have not, since we have servers connected to that and to do so would bring down the uplink for the top switch (since only the 1 stacking link is active)  But I can probably test it early in the morning.
Also, the stack had been up with no issues at all for a couple of days.  Switch 2 had been the master (it is not currently) when yesterday afternoon, my coworker unplugged the power cord of the master (bottom or switch 2) and re routed the power cord.  Pretty sure he did not touch the stacking cables, but could a problem develop from turning off the master in the stack?  When I saw the alert, which began right after he did that, the stacking link was reporting an issue.  I noticed that 2 was the master, and changed it (switch 1 priority 15, wr mem, reload) then since I usually like the top switch to be master - makes things neater. This morning some servers have been moved to the new stack with the stacking issues, so now it's harder just to reload or change the switch without causing service interruptions.  *sigh*
I finally found
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/troubleshooting/switch_stacks.html#wp39498
which indicates troubleshooting steps.
I found that the cable on switch 2 side, was not tightened evenly.
Now I have:
ServTierSw1#sho switch stack-ports summ
          Status                                          To LinkOK
  1/2     OK         2      50 cm     Yes    Yes    Yes       51        No
  2/1     OK         1      50 cm     Yes    Yes    Yes       49        No
ServTierSw1#
Thanks!
