3750 stack power connectivity
tyagi.v
Level 2
Level 2
What will be the recommended connectivity of stack power cable in 6 number of 3750x switches ?
Is it similar to the stack cable ?
Vijay
2 Accepted Solutions
A power stack can include a maximum of four switches. You can configure multiple power stacks within a data stack, but a power stack that spans multiple data stacks is not supported.
Inayath
*Plz dont forget to rate all usefull posts.
InayathUlla Sharieff
Thanks for the response
Does this mean we can have max 4 switches in power stack with default power stack cables(
CAB-SPWR-30CM or CAB-SPWR-150CM ) in ring topology ?
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750x_3560x/hardware/installation/guide/HIGINSTL.html#wp1348168
Inayath
