3750 Stacks
jasonmabry
Can you configure one switch with an IP address to be the stack master and leave the remainder of the switches with no configuration? Or, could you configure all of the switches with the same configuration so that if the existing stack master fails the newly elected master will have the same configuration?
garytayl
Level 3
Level 3
This document helped me to answer most of my questions, hopefully will do the same for you:
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml
