3750 Stackwise problem
nelsonm
Community Member
I have a stack consisting of 7 3750 switches, mixed 24T and 48P... When I hit the stack mode button between my switch 2 and 3 the port 23 on Switch 2 and the port 24 on switch 3 are amber.. ALl other switches in the stack have green lights indicating good link. Is this a potential bad cable or port? How can I verify. If it is a bad cable, can I replace without taking down the remaining stack members
b.hsu
Level 11
Level 11
Catalyst 3750-E switch StackWise cable: remove and inspect the cable and StackWise port for bent pins or damaged connectors. If the StackWise cable is bad, replace it with a known good cable.
For more information please click following URL:
http://www.cisco.com/en/US/products/ps7077/products_installation_guide_chapter09186a0080763909.html#wp1065008
