3750 Stackwise
aamaral2006
I can use just 01 stackwise cable to connect 02x3750 Switches. But, If I use 02 cables to connect him, Will I have any advantage or problem ? TKS
Roberto Salazar
Level 11
Level 11
You need 2 stackwise cables if you are trying to stack the switches.
See "Create a Switch Stack from Two Two-member Stacks"
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml#stack1
Roberto Salazar
Level 11
Level 11
Roberto, just wondering, from your reference, it appears 3 or more member stack will run in a "half bandwidth", no redundacy configuration if there's a stack member down or cable is missing/defective. So you're saying a 2 member stack will not function, as a stack, without both cables?
for 2 switch, you need 1 stackwise cable .
i don't think there is any advantage in using the second one .
more than 2 , you need the last one in the stack to connecto to the first to reseble a circular queue .
