3750 Switch Stack Configuration
Korimarchana
Community Member
Hello All,
I am new to networking and I am learning switch stacking configuration.I am having following having issues.
(Both switches are compatible to each other)
  • show switch stack-ports summary" command showed the port status as "absent" (indicating no cable detected on stack port even though Cable screws are tightened properly)
Switch-2A# show switch stack-ports summary
Switch#/ Stack Neighbor Cable Link Link Sync # In
Port# Port Length OK Active OK Changes Loopback
Status To LinkOK
1/1 Absent None No cable No No No 0 Yes
  • "show switch" command only detects "master", not the slave or the member
Switch-2A#en show switch
Switch/Stack Mac Address : e8b7.4843.1f00
H/W Current
Switch# Role Mac Address Priority Version State
*1 Master e8b7.4843.1f00 1 1 Ready
Help me figuring out what is going wrong int the configuration.
Thank You,
Archana
Reza Sharifi
Can you try using a different stacking cable and test again?
Reza Sharifi
Thanks for your response.
It worked after changing the cable.
Can you rate and mark the post as answered, so others can benefit from it?
