3750 switch
Hi all
question
is  possible to enable multicast option in cisco switch 3750g ports and how convinient si to do that.
the reason deliver imaging from ghost server to workstation  file size maybe 7 or 8 g...
thanks for all suggestions
sincerely
Carlos M
5 Replies 5
Reza Sharifi
Hi Carlos,
Yes, you can turn on multicast, but you need IP services image if you aleady don't have it.
Reza
thanks so much....
have agreat weekend
CM
question the image on the router correct? or just the switches or both....
On 3750s series, there is only one image that you need to install. One image does the routing and switching
Reza
