3750-X and ASA LAN and VPN routing question
jfgrenier
I'm having a little problem maybe with my understanding or with my routing.
I have a 3750X (192.168.1.1) stack and an ASA 5510 (192.168.1.2).
The ASA has some VPN tunnels established through internet to several other ASA locations/subnets (192.168.2, 192.168.3, 192.168.4...), plus I have other routed subnets in the LAN (routed through the 3750X).
In the 3750X, I have this satic route entered, and routes for routed ports on the switch :
ip route 0.0.0.0 0.0.0.0 192.168.1.2  (the ASA)
Now, I want my servers/users to have the 3750X as their default gateway (192.168.1.1) so that they can access everything, from the Internet to the routed subnets, to the ASA tunneled subnet.  Am I doing it right ?
In theory, it works, but in practice, something's wrong because it looks like the packets coming from the VPN/tunelled subnets get lost when they return, the TTL changes (by an increment of 1).
If I ping from 192.168.1.200 to 192.168.2.200 :
Forward Trip
(user1: 192.168.1.200) ---> (switch: 192.168.1.1) ---> (asa1: 192.168.1.2) <<vpntunnel>> (asa2: 192.168.2.2) ---> (user2: 192.168.2.200)
Return Trip
(user2: 192.168.2.200 ---> (asa2: 192.168.2.2) <<vpntunnel>> (asa1: 192.168.1.2) <<direct-lan>> (user1: 192.168.1.200)
It seems to confuse the applications as it looks like the forward and return trip are not exactly the same ?  Am I missing something in the ASA, should the packets be pushed back to the 3750X when it returns ?  If so, how do I do this ?
This is causing problems with almost every applications in terms of disconnection, network errors.
The only way to 'fix' those problems is to put the ASA as the default route on the users/servers workstations, instead of using the 3750X as the default route.
What's the right way to to this ?
Thanks !
JFG
Jon Marshall
You need a separate subnet between the 3750 and the ASA. There are 2 ways to do this  -
1) use a L3 routed port from the 3750 to the ASA
or
2) create a new vlan and use an SVI for the connection to the ASA.
You would also need to update your routing tables on the switch and ASA for both 1) and 2)
Which one to use depends on how many addresses you need in that subnet. If it is just the switch and ASA you can use either. But if, for example, you were going to be adding another ASA as a standby for redundancy you can only use option 2).
I generally use option 2.
So -
option 1
subnet = 192.168.5.0 255.255.255.252
3750
int gi0/0 <---- this connects to ASA
no switchport
ip address 192.168.5.1 255.255.255.252
ip route 0.0.0.0 0.0.0.0 192.168.5.2
ASA
on the ASA assign 192.168.5.2 255.255.255.252 to the inside interface
then for each subnet routed on the 3750 you now need routes eg.
route inside 192.168.1.0 255.255.255.0 192.168.5.1
Option 2
subnet = 192.168.5.0 255.255.255.248
vlan = 10 (this should be a new vlan)
ASA configuration is exactly the same except the subnet mask is different ie. 192.168.5.2 255.255.255.248
3750
vlan 10
int gi0/0  <-- this connects to ASA
switchport
switchport mode access
switchport access vlan 10
int vlan 10
ip address 192.168.5.1 255.255.255.248
no shut
Jon
