05-30-2014 01:04 PM - edited 03-07-2019 07:35 PM
Hi, I have just had a to revert a customer due to a failed install. Hoping someone can help.
Replacing an HP core with Cisco 3750's configured up all the vlan s and IP addresses. Created two port channels, 11 and 12 to take 10gig uplinks from cisco fabric interconnects (Currently they have 1gig connections into the HP). Plugged the 10 gigs, vlans cane up.. Dang switch wont ping the UCS manager on vlan 220 from either default vlan or using vlan 220 as a source. all VM's lost connections within the UCS (they are supposed to switch inside the FI's). Must be something wrong with my config pasted below... Had a laptop plugged into a port I configures as an access port on VLAN 220, could ping the ip address of the vlan 220 interface but not the interface of vlan 1 or the ucs manager. ANy help or pointers appreciated and apologies for the long post.
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2014.05.30 08:24:31 =~=~=~=~=~=~=~=~=~=~=~=
sh run
Building configuration...
Current configuration : 13110 bytes
version 12.2
no service pad
hostname vvvv
boot-start-marker
boot-end-marker
enable secret 5 vvv
username root privilege 15 secret 5 vvvv
no aaa new-model
switch 1 provision ws-c3750x-48
switch 2 provision ws-c3750x-48
system mtu routing 1500
ip routing
ip domain-name vvv
ip name-server 192.168.220.31
ip name-server 192.168.220.59
crypto pki trustpoint TP-self-signed-2806828672
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2806828672
revocation-check none
rsakeypair TP-self-signed-2806828672
crypto pki certificate chain TP-self-signed-2806828672
truncated
quit
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
switchport trunk allowed vlan 1,5,205,210,220,230,246,250
switchport mode trunk
interface Port-channel2
switchport access vlan 20
switchport trunk allowed vlan 1,205,210,220,230
interface Port-channel3
interface Port-channel4
switchport trunk allowed vlan 1,205,210,215,217,220,230
interface Port-channel5
interface Port-channel6
interface Port-channel7
switchport trunk allowed vlan 1,200,201,205,210,220
interface Port-channel8
switchport trunk allowed vlan 1,200,201,205,210,215,217,220
interface Port-channel9
interface Port-channel10
interface Port-channel11
interface Port-channel12
interface Port-channel13
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
interface GigabitEthernet1/0/1
description "Connected_to_Checkpoint_Internal_Interface"
switchport mode access
interface GigabitEthernet1/0/2
switchport access vlan 215
interface GigabitEthernet1/0/3
switchport access vlan 210
interface GigabitEthernet1/0/4
switchport access vlan 217
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
switchport access vlan 220
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
channel-group 10 mode active
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
channel-group 9 mode active
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
channel-group 8 mode active
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
channel-group 7 mode active
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
channel-group 6 mode active
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
channel-group 5 mode active
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
channel-group 4 mode active
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
channel-group 3 mode active
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
channel-group 2 mode active
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
channel-group 1 mode active
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
channel-group 11 mode on
interface TenGigabitEthernet1/1/2
channel-group 12 mode on
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/15
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
interface GigabitEthernet2/0/18
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
interface GigabitEthernet2/0/24
interface GigabitEthernet2/0/25
interface GigabitEthernet2/0/26
interface GigabitEthernet2/0/27
interface GigabitEthernet2/0/28
interface GigabitEthernet2/0/29
interface GigabitEthernet2/0/30
interface GigabitEthernet2/0/31
interface GigabitEthernet2/0/32
interface GigabitEthernet2/0/33
interface GigabitEthernet2/0/34
interface GigabitEthernet2/0/35
interface GigabitEthernet2/0/36
interface GigabitEthernet2/0/37
interface GigabitEthernet2/0/38
interface GigabitEthernet2/0/39
interface GigabitEthernet2/0/40
interface GigabitEthernet2/0/41
interface GigabitEthernet2/0/42
interface GigabitEthernet2/0/43
interface GigabitEthernet2/0/44
interface GigabitEthernet2/0/45
interface GigabitEthernet2/0/46
interface GigabitEthernet2/0/47
interface GigabitEthernet2/0/48
interface GigabitEthernet2/1/1
interface GigabitEthernet2/1/2
interface GigabitEthernet2/1/3
interface GigabitEthernet2/1/4
interface TenGigabitEthernet2/1/1
interface TenGigabitEthernet2/1/2
interface Vlan1
description Default
ip address 192.168.240.1 255.255.255.0
interface Vlan5
description VPN_Backup
no ip address
interface Vlan200
description Win7_Desktops
ip address 192.168.200.1 255.255.255.0
ip helper-address 192.168.220.50
ip helper-address 192.168.220.138
interface Vlan201
description XenServer_6.1
ip address 192.168.201.1 255.255.255.0
interface Vlan205
description XP_Desktops
ip address 192.168.205.1 255.255.255.0
interface Vlan210
description Thin_Clients
ip address 192.168.210.1 255.255.255.0
ip helper-address 192.168.220.58
interface Vlan215
description DMZ_Internal
no ip address
interface Vlan217
description DMZ_External
no ip address
interface Vlan220
description Servers
ip address 192.168.220.1 255.255.255.0
interface Vlan225
no ip address
interface Vlan230
description Voice_MXe
ip address 192.168.230.1 255.255.255.0
interface Vlan246
description CCTV
no ip address
interface Vlan250
description Xconnect_to_Foundry
ip address 192.168.250.220 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.240.254
ip http server
ip http secure-server
snmp-server community iwontusepublic RO unrestricted
snmp-server contact "Mark Guest" location "DP Core Switch"
snmp-server enable traps config-copy
snmp-server host 192.168.220.42 iwontusepublic
line con 0
exec-timeout 30 0
logging synchronous
login local
line vty 0 4
exec-timeout 30 0
logging synchronous
login local
transport input telnet ssh
line vty 5 15
exec-timeout 30 0
logging synchronous
login local
ntp server 192.168.220.31
end
05-30-2014 01:34 PM
Hmm. Did you create those VLANs on the switch? :) Also, check spanning-tree and check the trunk ports and make sure that the VLANs are allowed across. Also, make sure you allow the VLANs on the trunk from the FIC/UCS side as well.
05-30-2014 01:49 PM
Vlan Database..Vlan 1..Vlan 2 etc.. Right.. Yep did that but have been cought out here before :-)
Unless I am missing something "ip routing" should just spring it all to life shouldn't it?
The PO's were up and both links in them forwarding so the negotiation worked I assumed.
Vlans mush be assigned from the UCS side because it's working no, plugged into an HP switch (at 1g)
vlans were allowed because PO11 and 12 were configed with switchport mode trunk only
Could the UCS have been set to 220 native? Would that cause my issue?
05-30-2014 10:43 PM
OK so on more research the UCS only uses LACP so the channel group needs to be active not on.
int range ten 1/1/1, ten 1/1/2
no channel-group 11 mode on
channel-group 11 mode active...
etc.
I'll keep researching.
05-31-2014 12:44 AM
Sorry I somehow missed your previous comment.
About the native VLAN: You should definitely have it matching on both sides. Otherwise, it can definitely cause issues. For instance, if it is native 220 on the UCS but 1 on the switch then traffic from the UCS on VLAN 220 would come untagged across the trunk. Since the traffic does not have a VLAN tag the switch would assume that it should be riding on VLAN 1 (the local native VLAN) and vice-versa
You should issue show interface trunk and show CDP neighbor detail on the switch and post the output here.
About the port-channeling protocol: I have not worked much with UCS but even if it did support channel-group on, I would still recommend that you use LACP
A couple of other things to test:
1. From your test machine on VLAN 220, can you ping another host on that switch that is in a different VLAN?
2. From the same test machine can you ping another upstream device/IP. For instance, the default gateway or an upstream router/L3 switch...basically something other than UCS and hosts behind it
