3750-X switch won't connect to gigabit NIC
shootcraps1
Hi.  I'm setting up a 3750-X with fiber GLC-LH-SM SFPs.  I've got an AT-2916SX NIC.  The connection will not come up.  The switch and NIC settings are very basic, nothing fancy.  Both are set to Autonegotiate.  Do I have a compatibility issue?
Vincent.
5 Replies 5
Reza Sharifi
Try crossing the fiber stands on one side of the cable and than test again.
I tried that.  No joy.
ok, you SFP is long haul (GLC-LH-SM SFP)
Are you using a single mode fiber patch cord?
If yes, have you tried a different SFP?
We don't have any SM so I'm using MM.  I have an LC-LC cable and when I connect it to two ports, they come up.  I've also patched two LC-SC cables and the ports come up.
I've swapped the SFPs too.
We might have an answer.  We think the GLC-LH-SM modules won't talk to the SX NIC.  We've ordered some GLC-SX-MMD modules to test.
