3750E sh int - output drop incoherent display
ogor
I use the command "show interface" to display the interface's stats on my Core swith (WS-C3750E-48PD-EF in 12.2(35r)SE1) and the display is completly incoherent ???
First with 0 output drops
and after 43489 output drops
then 0 output drop again
and this in few seconds ?
Is there a bug on the display ?
This symptom is the same others interfaces.
thanks
Olivier
Joseph W. Doherty
Agreed, it sure doesn't look correct.
If you have maintenance, since you're 3750E is running 12.2(44)SE1, you might first try 12.2(44)SE5. (NB: the 12.2(35r)SE1 is the boot software.) Or, if you have maintenance, something to bring to TAC.
