3750E stacked Switch is running out of MAC-address space
manokma01
on a cisco 3750e stacked switch , we are running out of mac-address space.
eg:  Total Mac Address Space Available: 0
The current template is "desktop default" template i was of the opinion to change the Default SDM template or break out the stack.
Any other suggestions ? any way to check why so many mac-address are present in device?
Mark Malone
Desktop default only allows 6000 macs , change it to template vlan you will get 12000 macs allowed
Other than that yes break the stack you will get 6000 back per switch , also check your timers are not too long and switch is storing macs that are not even in use
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_55_se/configuration/guide/scg3750/swsdm.html
