3750g and 3750 difference
shridhar76
What is the difference betwen cisco 3750 and 3750g l3 switch. G means dose all ports of that switch behaves like gigabit ports or what. pls clarify me.
shridhar
Kuppannagar,
As per your question,G means all ports are Gigabitport.
HTH,
Toshi
Jagdeep Gambhir
Level 10
Level 10
Right, the only difference between the Cat 3750 and the Cat 3750G platforms is that there are more port ASICs on the G platform.
~JG
Do rate helpful posts
Joseph W. Doherty
Another difference, the "G" (gig) suffix 3750 switches might have insufficient fabric bandwidth and/or PPS performance to support all ports running concurrently at wire-speed.
