3750G Memory Pool
Lkwoods82
Community Member
Does the 3750G divide blocks of memory between adjacent ports?  We have 6 high use devices on ports 1 through 6 and I was told that splitting them up allocates memory better.  Is this correct?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising  out of the use or inability to use the posting's information even if  Author has been advised of the possibility of such damage.
Posting
I don't know about memory blocks being shared by groups of ports, wouldn't think so, but believe groups of ports share access to the 32 Gbps fabric and ASICs, so you might improve performance by wider distribution of your busy ports.
Memory allocations, if QoS enabled, are shared by all ports in the same queue set, so busy ports might benefit from being in a different queue set where memory can be allocated differently.
