3750G port grouping per asic
mp.wong
I have a 48-port 3750G switch (model # WS-C3750G-48TS-S).  How do I determine which ports are grouped per ASIC on the 3750G switch?
For example, is the grouping ports 1-8 is serviced by ASIC 1, ports 9-16 is serviced by ASIC 2, ports 17-24 is serviced by ASIC 3, etc.
If it exists, what is the IOS command to show the mapping of ports to ASIC?
Peter Paluch
I am not sure if it works for you but try using the command show platform pm platform-block - it lists the individual ports including the indication of the ASIC the port is serviced by.
Best regards,
Peter
Hello Peter - that command worked and provided the information I needed on the 3750, which is 4 consecutive ports per ASIC.
Michael
