3750g port not displaying DSCP QOS
MARK CASEY
I have a 3750G switch with a port  that I have setup qos on that is set for dscp but doesn't show any dscp stats
interface FastEthernet1/0/2
 description Pegasus-NextDC Interface
 switchport access vlan 1001
 switchport mode dot1q-tunnel
 srr-queue bandwidth share 1 30 60 5
 srr-queue bandwidth shape 10 0 0 0
 srr-queue bandwidth limit 20
 queue-set 2
 priority-queue out
 mls qos trust dscp
 l2protocol-tunnel cdp
 l2protocol-tunnel vtp
 no cdp enable
MSA-nextDC-Interface#show mls qos int fast 1/0/2
FastEthernet1/0/2
trust state: trust dscp
trust mode: trust dscp
trust enabled flag: ena
COS override: dis
default COS: 0
DSCP Mutation Map: Default DSCP Mutation Map
Trust device: none
qos mode: port-based
FastEthernet1/0/2 (All statistics are in packets)
  dscp: incoming
  0 -  4 :           0            0            0            0            0
  5 -  9 :           0            0            0            0            0
 10 - 14 :           0            0            0            0            0
 15 - 19 :           0            0            0            0            0
 20 - 24 :           0            0            0            0            0
 25 - 29 :           0            0            0            0            0
 30 - 34 :           0            0            0            0            0
 35 - 39 :           0            0            0            0            0
 40 - 44 :           0            0            0            0            0
 45 - 49 :           0            0            0            0            0
 50 - 54 :           0            0            0            0            0
 55 - 59 :           0            0            0            0            0
 60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :           0            0            0            0            0
  5 -  9 :           0            0            0            0            0
 10 - 14 :           0            0            0            0            0
 15 - 19 :           0            0            0            0            0
 20 - 24 :           0            0            0            0            0
 25 - 29 :           0            0            0            0            0
 30 - 34 :           0            0            0            0            0
 35 - 39 :           0            0            0            0            0
 40 - 44 :           0            0            0            0            0
 45 - 49 :           0            0            0            0            0
 50 - 54 :           0            0            0            0            0
 55 - 59 :           0            0            0            0            0
 60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :       22358            0            0            0            0
  5 -  7 :           0            0            0
  cos: outgoing
  0 -  4 :        1274            0            0          116            0
  5 -  7 :       20245          274            0
  output queues enqueued:
 queue:    threshold1   threshold2   threshold3
 queue 0:           0           0       20240
 queue 1:          40         302         299
 queue 2:           0           0        1577
 queue 3:           0           0           0
  output queues dropped:
 queue 0:           0           0           0
 queue 1:           0           0           0
 queue 2:           0           0           0
 queue 3:           0           0           0
Other ports on this switch are showing DSCP stats, just not this port.
You might ask if the packets that are passing through the port have DSCP tags, the answer is yes.
This port connects to another switch that has the following settings and results, ie dscp settings on the packets going through it
interface FastEthernet3/0/2
 description Pegasus-20MB-Interface
 switchport trunk native vlan 5
 switchport trunk allowed vlan 27-30,33,97,99,132,996,997
 switchport mode trunk
 speed 100
 srr-queue bandwidth shape 3 0 0 0
 queue-set 2
 priority-queue out
 mls qos trust dscp
 macro description cisco-router | cisco-router
nextDC-3750-Internal# show mls qos int fast 3/0/2 statistics
FastEthernet3/0/2 (All statistics are in packets)
  dscp: incoming
  0 -  4 :     1069264            0            0            0            0
  5 -  9 :           0            0            0            0            0
 10 - 14 :           0            0            0            0            0
 15 - 19 :           0            0            0            0            0
 20 - 24 :           0            0            0            0            0
 25 - 29 :           0       112997            0            0            0
 30 - 34 :           0            0            0            0            0
 35 - 39 :           0            0            0            0            0
 40 - 44 :           0            0            0            0            0
 45 - 49 :           0     25225958            0       425389            0
 50 - 54 :         673            0            0            0           29
 55 - 59 :           0            0            0            0            0
 60 - 64 :           0            0            0            0
  dscp: outgoing
  0 -  4 :      310451            0            0            0            0
  5 -  9 :           0            0            0            0            0
 10 - 14 :           0            0            0            0            0
 15 - 19 :           0            0            0            0            0
 20 - 24 :           0            0            0            0            0
 25 - 29 :           0        79530            0            0            0
 30 - 34 :           0            0            0            0            0
 35 - 39 :           0            0            0            0            0
 40 - 44 :           0            0            0            0            0
 45 - 49 :           0     25409743            0       138169            0
 50 - 54 :           0            0            0            0            0
 55 - 59 :           0            0            0            0            0
 60 - 64 :           0            0            0            0
  cos: incoming
  0 -  4 :     1122497            0            0       112997            0
  5 -  7 :    25225958       426091         4392
  cos: outgoing
  0 -  4 :      449196            0            0        79530            0
  5 -  7 :    25409743       138169          178
 queue 0:    25410756       79530           0
 queue 1:      121922       41277     1995718
 queue 2:           0           0      300011
 queue 3:           0           0       11537
 queue 0:           0           0           0
 queue 1:           0           0           0
 queue 2:           0           0        1979
 queue 3:           0           0           0
Policer: Inprofile:            0 OutofProfile:            0
Anyone got any ideas why this port is not using DSCP ?
Thanks in Advance
Mark
Hello Mark,
as I understand it (since you have the port configured as a dot1q tunnel), the frames on your port are tagged, and the switch resets the CoS value to 0, and subsequently the CoS to DSCP table sets the DSCP value to 0 as well.
You could try and change the default DSCP-to-Cos map, as in this example:
3750G(config)# mls qos map dscp-cos 16 18 24 26 to 1
3750G(config)# mls qos map dscp-cos 0 8 10 to 0
