3750G stack-switch reboot
shaqpappi
Community Member
Is there a way reboot a single switch in a stack configuration? After a power outage my switches reversed roles so my master became the slave and slave became master. I wanted to reboot only one switch so the remaining would assume the master role again.
Reza Sharifi
You can use this command to reload a specific switch in the stack
reload slot xx
slot number is the switch number in the stack
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_50_se/command/reference/cli1.html#wp10820065
Reza
Reza Sharifi
reload slot xx
Reza
smogra
Use "reload" command as explained by Reza above.
And if you want that switch to be the master all the time, set its priority to be highest (say 5). This way the desired switch will become master always.
switch stack-member-number priority new-priority-value
Cheers
Sweta
Please rate the content if it was helpful.
I believe stack master election will take place only if the reload command is issued from the master.
Ideally, the master will bootup first and it will wait for the other stack members to load inorder to form a stack.
Booting sequence:
checking for Bootloader upgrade.. not needed
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
Waiting for Stack Master Election...
POST: PortASIC CAM Subsystem Tests : Begin
So we need to set the priority of the switches and we need to reload the entire stack inorder to make our interested switch as master.
Setting a priority will not take into effect unless the master is reloaded.
you can perform a reload of the member using the below command as well
remote command reload
Hope this helps
Cheers
Somu
please rate this answer if the information was useful
