3750G Stuck in Bootloader
aarocarso
Hello!
My issue is as follows:
I have just received a new Cisco 3750G Switch from my parent company. When attempting to install the switch, I discovered that it will not boot to CLI, only to the bootloader. After using the command boot, the switch attempts to boot the most current IOS version, but fails, stating "error loading XXXXXXXXXX.bin".
Obviously, I just need to get a functional version of the IOS onto the switch to boot, but the problem is exactly how can I do that? All (or most) the commands with which I am familiar are unavailable in the bootloader, so all methods known to me fail. Is there a simple way (maybe using the copy command?) to put the .tar or .bin file onto the flash?
Thank you in advance for all of your assistance!
This is exactly what I need. Thank you for the link!
