09-10-2012 08:24 AM - edited 03-07-2019 08:47 AM
Hey, I couldn't find anywhere online that would give me the full feature set for IP Base with the 3750x.
I just wanted to verify that I could create a routed port, turn ip routing on, and create static routes as well
as a default route. From what I can find, there shouldn't be a problem with this on the IP Base Feature
Set, I just wanted to verify. Or if anyone knows of a link for the Features of IP Base on the 3750x.
Solved! Go to Solution.
09-10-2012 08:27 AM
Hello John,
you can use feature navigator search by image name to find all the features supported
In any case what you would like to do is really basic and should be supported in IPBase
Hope to help
Giuseppe
09-10-2012 08:27 AM
Hello John,
Hope to help
Giuseppe
09-10-2012 09:21 AM
Hi John,
this should be a more specific link (for what you are looking for) of what Giuseppe has already provided you:
http://www.cisco.com/cisco/software/navigator.html?mdfid=282895850&i=rm
Make sure to be logged in before opening this link and choose the specific model/IOS you have in. After choosing the 3750 model you have in place,choose the image you want to see and click on the bottom left view features
If you post me the precise 3750x switch model you have i can provide a better link.
Alessio
09-10-2012 05:06 PM
Thanks for all the help everyone.
