3750X-48PF-E USB Console Does Not Work
DJX995
Level 3
Level 3
I tried on two different computers (Windows 7 x64 and Windows 7 x86).
I can't get the USB console to work on my 3750X.
I checked device manager and it shows the port install OK, no problems.
When I try to connect to it using Putty, it acts like it's not there saying "Unable to open serial port"
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.2(1)E2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Thu 13-Mar-14 03:26 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
core3750x uptime is 3 hours, 38 minutes
System restarted at 21:27:30 EDT Tue Mar 29 2011
System image file is "flash:/c3750e-universalk9-mz.152-1.E2/c3750e-universalk9-mz.152-1.E2.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipservices
License Type: Permanent
Next reload license Level: ipservices
cisco WS-C3750X-48P (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1635P0VH
Last reset from power-on
4 Virtual Ethernet interfaces
1 FastEthernet interface
52 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : FC:99:47:F8:C1:80
Motherboard assembly number     : 73-12553-06
Motherboard serial number       : FDO16350G6L
Model revision number           : A0
Motherboard revision number     : A0
Model number                    : WS-C3750X-48PF-E
Daughterboard assembly number   : 800-32727-03
Daughterboard serial number     : FDO163509K9
System serial number            : FDO1635P0VH
Top Assembly Part Number        : 800-31324-03
Top Assembly Revision Number    : B0
Version ID                      : V03
CLEI Code Number                : COMJZ00ARC
Hardware Board Revision Number  : 0x04
Switch Ports Model              SW Version            SW Image
*    1 54    WS-C3750X-48P      15.2(1)E2             C3750E-UNIVERSALK9-M
Configuration register is 0xF
Any suggestions?
Reza Sharifi
http://software.cisco.com/download/release.html?mdfid=282867574&softwareid=282855122&release=3.1
Try downloading the driver from the link
That is the software I am using (or trying to use).
MD5: eff2e955edcdc70209e6f9c8f6bd59cd
