3750x IP Base Routing Features
JohnTylerPearce
Level 7
Level 7
I just wanted to verify the following information. If you have a stack of 2 switches, and the stack master has IP Base, and the bottom switch doesn't then both switches will support IP Base features since the Stack Master has IP Base.
Second, IP Base only supports static routing, RIP, and EIGRP Stub routing..
My other question is, how many routes can you have with with IPv4 or is there a limit?
Sandeep Choudhary
Hi John,
Direct anser NO, they will not support each other, for support they have to have same ios version(Ipbase).otherwise only master will run.
Yes, RIP and static routing are supported on the IP Base feature set. Dynamic IP routing protocols (OSPF, BGPv4, EIGRP) are available only on the IP Services feature set.The IP Base feature set enables Layer 2 forwarding, high-availability, QoS and security features along with basic Layer 3 routing, including EIGRP stub mode.
as per my knowledge, there is no limit.But am note sure about this!
Please rate if it helps.
As Sandeep already replied for the first two questions,
i 'll reply to the third
The limit is your RAM memory. The computational capability will not represent a  problem for your switch (very performing) but the dimensions of the routing tables always impact on the RAM memory.
Upgrade your license if you can otherwise you will not be able to get the best from that so nice machine !
Alessio
