3750X OSPF, VRF Scalability
HUBERT RESCH
Level 3
Level 3
Hi we are planing a routed network consisting of up to 100 3750X Stacks. We want to deploy up to 10 isolated networks with VRF-lite on the Switches.
Every Stack has up to 8 OSPF/EIGRP neighbors per VRF. The Routingtable of every VRF is smaller than 1K Routes
So my Questions
The max. number of VRFs ist more than 10 , What I found so far it should be up to 26, correct?
The max numbers of OSPF or EIGRP Processes I could not find out from the documentation, any hint where to find this number, is it larger than 10 as well?
Assuming that every VRF has up to 8 OSPF/EIGRP neighbors the total number would be up to 80 total neighbors per switch, will this work from the cpu perspective?
Thanks in Advance
Hubert
0 Replies 0
