3750x stacking
adnan.akbar
Community Member
hello ,
i have a stack of 5 3750x switches installed and i have another location with 1 switch  , i took one of the 5 switches ( last switch # 5 ) and stacked it to the standalone switch . everything works fine , except for the interfcaces , it still considers the switch to be # 5 , not # 2 in the new stack .
example
nterface GigabitEthernet1/0/47
switchport access vlan 120
switchport mode access
duplex full
spanning-tree portfast
interface GigabitEthernet1/0/48
duplex full
interface GigabitEthernet1/1/1
switchport mode trunk
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface GigabitEthernet5/0/1
duplex full
interface GigabitEthernet5/0/2
interface GigabitEthernet5/0/3
interface GigabitEthernet5/0/4
interface GigabitEthernet5/0/5
interface GigabitEthernet5/0/6
i have  reset the configuration on the swwitch which i added to the new stack .
any  idea inb how to change this to make  the interfaces start with 2/0/x ? instead of 5 ? !
one more thing , i have boith swtiches connected with the power stack cable , however , it does not work , any commands i have to run on the switches ?!
thanks .
ankugarg
Level 7
Level 7
Use the command "switch 5 renumber 2",and reload.
ankugarg
Level 7
Level 7
so , i'll connect to using console to switch 5 , use this comand and reload only the switch 5 or the whole stack ?
adnan.akbar
Community Member
i have renumbered the switch , and reloaded the slot .
when i do show switch command , the old number is still availabed with Removed on the current status
Switch/Stack Mac Address : 30e4.db45.cd80
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 30e4.db45.cd80     1      1       Ready
2       Member 30e4.db47.0380     1      1       Ready
5       Member 0000.0000.0000     0      1       Removed
and when i do show run , i still get the old interfaces for switch 5 .
interface GigabitEthernet2/0/48
interface GigabitEthernet2/1/1
interface GigabitEthernet2/1/2
interface GigabitEthernet2/1/3
interface GigabitEthernet2/1/4
interface TenGigabitEthernet2/1/1
interface TenGigabitEthernet2/1/2
duplex full
how can u remove switch 5 interfaces related to the old number of the switch
In show run,you will be having like this for switch 5--
switch 1 provision ws-c3750e-24td
switch 2 provision ws-c3750e-24td
switch 3 provision ws-c3750e-24td
Remove this for switch 5 ,by using 'no' version of the command.Shouldn't be seen after that.
