group multicast
mfouad.jahmi
Community Member
hi,
how to configure a group multicast for ex 224.0.0.41 ?
i have edge switches and L3 switches, do i have to implement them on all swiches ?
thx
5 Replies 5
Hi Mohamad,
Depends on where the multicast server/reciever sit? Are they on the same switch or different switches. If they span across different switches then you need to enable multicast routing on those switches where you have the multicast source/receivers.
Let us know if you want further info and also a diagram of your network would be good to help you more
Kishore
hi,
the DHCP server resides on one of the edge switches and all devices to belong to the same vlan are intsalled accross the other edge switches.
in this case do i have to configure ip multicast on the interface vlan ?
also what are the commands in order to do that ?
thanks kishore
Hi Mohamad.
I set up a similar one last week.
If its INTRA vlan multicast then all you need to do is enable PIM on the vlan interface.  The config is as follows
L3 switch
ip multicast-routing
int vlan
ip pim dense-mode
L2 switches
ip igmp-snooping
This should be enuff.
Ksihore
hi,
much appreciated.
i configured whats above. so in this case no need to staticlly configure ip multicat 224.0.1.41 ?
how to troubleshoot multicast for vlan# is properly workign fine ?
thanks alot
Well the source sends to that multicast group address and the receivers simpky join that group.
So you dont need to do anything extra. I would recommend using the 239.x.x.x range as its a private multicast group.
But if you need to use that 224 address then go for it
please see below for some handy commands and all for treoubleshooting
http://www.cisco.com/en/US/tech/tk828/technologies_tech_note09186a0080094b55.shtml
http://www.cisco.com/en/US/tech/tk828/technologies_tech_note09186a0080093f21.shtml
Kishore
