3750x switch - dead?
Michael Kim
Hello all,
I recently was trying to upgrade the OS on my two 3750-X stacked switches (both WS-C3750X-48PF-S) and the upgrade took successfully on the master switch but the other switch reboots to a "switch:" prompt.
Looking at the boot process it appears I've got a bad flash on this system.  I've tried the flash_init command and format to no avail.  I've also tried to boot off a USB drive on the device and it loads IOS but then the system executes a "%Software-forced reload" soon after and I'm back at the switch: prompt.  I know the IOS bin file is good since I used it to load onto a spare switch of the same model.
At this point I'm assuming I've got a hardware issue with the flash storage but since I can't RMA (no smartnet) what are my options? Do I just have a useless device at this point since I can't get it to boot IOS no matter what I've tried?  Is the flash storage replaceble?
Not that it really matters but I was trying to upgrade from "c3750e-ipbasek9-mz.122-55.SE5.bin" to "c3750e-universalk9npe-mz.150-2.SE10a.bin"
Thanks for any assistance.
Mike
SNIPPETS FROM SWITCH OUTPUT
Using driver version 1 for media type 2
Base ethernet MAC Address: 44:2b:03:9e:83:80
Xmodem file system is available.
The password-recovery mechanism is enabled.
Initializing Flash...
mifs[2]: 10 files, 1 directories
mifs[2]: Total bytes     :    2097152
mifs[2]: Bytes used      :     612864
mifs[2]: Bytes available :    1484288
mifs[2]: mifs fsck took 2 seconds.
mifs[3]: 0 files, 1 directories
mifs[3]: Total bytes     :    4194304
mifs[3]: Bytes used      :       1024
mifs[3]: Bytes available :    4193280
mifs[3]: mifs fsck took 3 seconds.
mifs[4]: 5 files, 1 directories
mifs[4]: Total bytes     :     524288
mifs[4]: Bytes used      :       9216
mifs[4]: Bytes available :     515072
mifs[4]: mifs fsck took 0 seconds.
mifs[5]: 5 files, 1 directories
mifs[5]: Total bytes     :     524288
mifs[5]: Bytes used      :       9216
mifs[5]: Bytes available :     515072
mifs[5]: mifs fsck took 1 seconds.
Failed to read sector (c/h/s = 436/2/6): device not ready for data xfer.
mifs[6]: Error reading sector 96069 error 3
Failed to read sector (c/h/s = 435/3/18): device not ready for cmd.
mifs[6]: Error reading sector 95857 error 3
Failed to read sector (c/h/s = 435/1/6): device not ready for cmd.
mifs[6]: Error reading sector 95781 error 3
Failed to read sector (c/h/s = 435/1/15): device not ready for cmd.
mifs[6]: Error reading sector 95790 error 3
Failed to write sector (c/h/s = 61/0/2): device not ready for cmd.
mifs[6]: Error writing sector 1 error 3
mifs[6]: Root directory corrupted!
mifs[6]: Failed to do fsck
...done Initializing Flash.
The system has been interrupted, or encountered an error
during initializion of the flash filesystem.  The following
commands will initialize the flash filesystem, and finish
loading the operating system software:
    flash_init
    boot
switch: flash_init
Failed to read sector (c/h/s = 61/0/2): device not ready for cmd.
mifs[6]: Error reading sector 1 error 3
mifs[6]: directory[1] is corrupted! Attempting to restore it
mifs[6]: Failed to restore directory[1]
switch: dir
List of filesystems currently registered:
                  bs[0]: (read-only)
               flash[6]: (read-write)
              xmodem[7]: (read-only)
                null[8]: (read-write)
                tftp[9]: (read-only)
switch: dir flash:
unable to stat flash:/: invalid argument
switch: boot usbflash0:/c3750e-universalk9npe-mz.150-2.SE10a.bin
Loading "usbflash0:/c3750e-universalk9npe-mz.150-2.SE10a.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "usbflash0:/c3750e-universalk9npe-mz.150-2.SE10a.bin" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9NPE-M), Version 15.0(2)SE10a, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Thu 03-Nov-16 13:41 by prod_rel_team
HULC:Collect Entropy thread starting on box...
Initializing flashfs...
Using driver version 3 for media type 1
Can't set variable with illegal char " (0xFFFFFFFF) in name.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not required (Stage 2)
FIPS: Fatal failure: sp800108 failed
 00:00:06 UTC Mon Mar 1 1993: Unexpected exception to CPUvector 2000, PC = 26E6028
-Traceback= 0x26E6028z 0x213674Cz 0x2136060z 0x1C56794z 0x1C56954z 0x1C56A70z 0x510A48z 0x510CB0z 0x26E730Cz 0x26E18C0z
 00:00:06 UTC Mon Mar 1 1993: Unexpected exception to CPUvector 2000, PC = 26E72E8
-Traceback= 0x26E72E8z
=== Flushing messages (00:00:06 UTC Mon Mar 1 1993) ===
Buffered messages:
Queued messages:
*Mar  1 00:00:06.752: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar  1 00:00:03.665: Read env variable - LICENSE_BOOT_LEVEL =
*Mar  1 00:00:03.665: %LICENSE-2-VLS_ERROR: 'VLSaddLicenseStorage' failed with an error - rc = 145 - 'Error[145]: Failure in creating/opening the store.'
-Traceback= 5012F4z 3A214z 82B0z 510810z 510CB0z 26E730Cz 26E18C0z
*Mar  1 00:00:03.665: %HULC_LICENSE-1-LICENSE_REGISTER_FAILED: license register license storage 'flash:' failed - rc = 24
*Mar  1 00:00:03.674: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3750x Next reboot level = lanbase and License = No valid license found
Debug Exception (Could be NULL pointer dereference) Exception (0x2000)!
SRR0 = 0x01C98368  SRR1 = 0x00029230  SRR2 = 0x026E6028  SRR3 = 0x00029230
ESR = 0x00000000  DEAR = 0x00000000  TSR = 0x84000000  DBSR = 0x10000000
CPU Register Context:
Vector = 0x00002000  PC = 0x026E6028  MSR = 0x00029230  CR = 0x35003033
LR = 0x026E5FC4  CTR = 0x004ED8D8  XER = 0xA0000054
R0 = 0x026E5FC4  R1 = 0x04E193C0  R2 = 0x00000000  R3 = 0x041DCBDC
R4 = 0x00000000  R5 = 0x00000000  R6 = 0x04E19390  R7 = 0x041B0000
R8 = 0x00029230  R9 = 0x041B0000  R10 = 0x00029230  R11 = 0x00000000
R12 = 0x35003039  R13 = 0x0B98279C  R14 = 0x00510C68  R15 = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00000000  R19 = 0x00000000
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00000000  R23 = 0x00000000
R24 = 0x00000000  R25 = 0x00000000  R26 = 0x04E19460  R27 = 0x03DB0000
R28 = 0x00000009  R29 = 0x04113B6C  R30 = 0x03DB1538  R31 = 0x00000000
Stack trace:
PC = 0x026E6028, SP = 0x04E193C0
Frame 00: SP = 0x04E193D0    PC = 0x026E5FC4
Frame 01: SP = 0x04E193D8    PC = 0x0213674C
Frame 02: SP = 0x04E193E0    PC = 0x02136060
Frame 03: SP = 0x04E193F0    PC = 0x01C56794
Frame 04: SP = 0x04E19410    PC = 0x01C56954
Frame 05: SP = 0x04E19428    PC = 0x01C56A70
Frame 06: SP = 0x04E19458    PC = 0x00510A48
Frame 07: SP = 0x04E19560    PC = 0x00510CB0
Frame 08: SP = 0x04E19568    PC = 0x026E730C
Frame 09: SP = 0x00000000    PC = 0x026E18C0
Switch uptime is 9 seconds
cisco WS-C3750X-48P (PowerPC405) processor with 262144K bytes of memory.
mifs[4]: mifs fsck took 1 seconds.
mifs[5]: mifs fsck took 0 seconds.
    flash_init
    boot
switch:
5 Replies 5
Mark Malone
Hi Michael
you could try this doc it has a few steps in it from switch prompt , if its not working at all you could try format it and then test the flash with the commands in the doc see if it gets you anywhere , did you also try boot back in the old image as a test
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_55_se/commmand/reference/3750cr/bootldr.html#pgfId-1004003
Mark,
I followed the link and tried some of the commands ... see below.  I also tried booting the old image from USB and it seems to load successfully but then it gives "%software-forced reload" message.
All things seem to point to a bad flash but what I'm not understanding is why when I boot from USB (ignoring flash) does it not load IOS completely.  If it did then the switch may still be usable.
Is the flash on the 3750x switches removable/replaceable?
switch: dir flash:
switch: format flash:
Are you sure you want to format "flash:" (all data will be lost) (y/n)?y
Failed to write sector (c/h/s = 61/0/1): device not ready for cmd.
mifs[6]: Failed to create superblock
Filesystem "flash:" not formatted -- I/O error
switch: erase flash:
Unknown cmd: erase
switch: fsck -test -f flash:
Are you sure you want to fsck "flash:" (could take some time) (y/n)?y
Filesystem "flash:" not checked -- I/O error
switch:
switch: boot usbflash0:c3750e-ipbasek9-mz.122-55.SE5.bin
Loading "usbflash0:c3750e-ipbasek9-mz.122-55.SE5.bin"...@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
File "usbflash0:c3750e-ipbasek9-mz.122-55.SE5.bin" uncompressed and installed, entry point: 0x3000
executing...
           cisco Systems, Inc.
Cisco IOS Software, C3750E Software (C3750E-IPBASEK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 09-Feb-12 18:14 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
Checking for Bootloader upgrade.. not needed
LANBASE Init...
Invalid parameter block. Using MAC address of 0:0:0:0:0:0
driver class subsystem initialization failed
 00:00:03 UTC Mon Mar 1 1993: Unexpected exception to CPUvector 2000, PC = 1F0E6F8
-Traceback= 1F0E6F8 1F0E6BC 1335D08 1335DA0 409758 4099C4 1F106C8 1F07140
=== Flushing messages (00:00:03 UTC Mon Mar 1 1993) ===
Buffered messages:
Queued messages:
*Mar  1 00:00:03.414: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Mar  1 00:00:02.508: Read env variable - LICENSE_BOOT_LEVEL =
*Mar  1 00:00:02.516: %LICENSE-2-VLS_ERROR: 'VLSaddLicenseStorage' failed with an error - rc = 145 - 'Error[145]: Failure in creating/opening the store.'
-Traceback= 28F4C 8F00 409550 4099C4 1F106C8 1F07140
*Mar  1 00:00:02.516: %HULC_LICENSE-1-LICENSE_REGISTER_FAILED: license register license storage 'flash:' failed - rc = 24
*Mar  1 00:00:02.516: %IOS_LICENSE_IMAGE_APPLICATION-6-LICENSE_LEVEL: Module name = c3750x Next reboot level = lanbase and License = No valid license found
*Mar  1 00:00:02.986: %PLATFORM_IPC-3-COMMON: Init failed before IPC init
-Traceback= 190F824 17E2134 1335D08 1335DA0 409758 4099C4 1F106C8 1F07140
SRR0 = 0x0135BB34  SRR1 = 0x00029230  SRR2 = 0x01F0E6F8  SRR3 = 0x00029230
Vector = 0x00002000  PC = 0x01F0E6F8  MSR = 0x00029230  CR = 0x59000093
LR = 0x01F0E6BC  CTR = 0x01309250  XER = 0x80000054
R0 = 0x01F0E6BC  R1 = 0x03EE87F0  R2 = 0x00000000  R3 = 0x00000000
R4 = 0xFFFFFFFE  R5 = 0x00000000  R6 = 0x03EE87D8  R7 = 0x00000000
R8 = 0x00000000  R9 = 0x033F4984  R10 = 0x033D0000  R11 = 0x00000000
R12 = 0x00000E75  R13 = 0x0B98279C  R14 = 0x00409964  R15 = 0x00000000
R24 = 0x00000000  R25 = 0x00000000  R26 = 0x00000000  R27 = 0x00000000
R28 = 0x00000009  R29 = 0x00000000  R30 = 0x03EE8808  R31 = 0x00000000
Stack trace:
PC = 0x01F0E6F8, SP = 0x03EE87F0
Frame 00: SP = 0x03EE8800    PC = 0x01F0E6BC
Frame 01: SP = 0x03EE8820    PC = 0x017E2AEC
Frame 02: SP = 0x03EE8828    PC = 0x01335D08
Frame 03: SP = 0x03EE8840    PC = 0x01335DA0
Frame 04: SP = 0x03EE8860    PC = 0x00409758
Frame 05: SP = 0x03EE8968    PC = 0x004099C4
Frame 06: SP = 0x03EE8970    PC = 0x01F106C8
Frame 07: SP = 0x00000000    PC = 0x01F07140
Switch uptime is 6 seconds
Reza Sharifi
Since you are upgrading from an standard image to a Universal image, it appears that the switch is not able to load the software license correctly and as a result it crashes.
Do both switches have the same license level?
In addition to Mark's comments and as a last resort, you can try reverting to the old image using xmodem.
Thanks for pointing out the license issue.  I wonder though that since the flash storage is unusable and that's the reason for the license error.  "Failure in creating/opening the store.'
Mike
It appears to be so, but can't be100% sure.  If you revert to the old image and the problem goes away, than I think we are on the right track with the license issue.
Licenses issues are pain to deal with.
