3750x Switch Inter-Vlan routing
St3v3n-zn
I would just like to find out what feature set the 3750x needs to be able to enable the "ip routing" command.
It currently has the LAN base feature set, which does not have this command.
Can it be done on the IP BASE feature set ? or the IP SERVICES set ?
cadet alain
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-x-series-switches/qa_c67-578933.html
As noted here you can do static routing with LAN Base.
Alain
