3750x using MAB and FreeRadius - Authorization failure
pjjoh1001
Hi All,
I am trying to get a 3750X to authenticate using MAB and to assign a VLAN to the port.  I can see that I get proper authentication but authorization always fails even though I can see the appropriate attributes comeing from the RADIUS (FreeRADIUS) server.
Mar 31 22:40:13.960: %AUTHMGR-5-START: Starting 'mab' for client (406c.8f1e.360f) on Interface Gi2/0/27 AuditSessionID 0A0A0A270000015009B394AF
Mar 31 22:40:13.977: %MAB-5-SUCCESS: Authentication successful for client (406c.8f1e.360f) on Interface Gi2/0/27 AuditSessionID 0A0A0A270000015009B394AF
Mar 31 22:40:13.994: %AUTHMGR-5-FAIL: Authorization failed or unapplied for client (406c.8f1e.360f) on Interface Gi2/0/27 AuditSessionID 0A0A0A270000015009B394AF
Mar 31 22:40:14.002: %AUTHMGR-5-FAIL: Authorization failed or unapplied for client (406c.8f1e.360f) on Interface Gi2/0/27 AuditSessionID 0A0A0A270000015009B394AF
Configuration:
aaa new-model
aaa authentication login default group radius local
aaa authentication dot1x default group radius
aaa authorization network default group radius
aaa accounting dot1x default start-stop group radius
aaa session-id common
ip radius source-interface Vlan100
radius-server host 10.10.10.235 auth-port 1812 acct-port 1813
radius-server key 7 1511021F0725
interface GigabitEthernet2/0/27
switchport access vlan 110
switchport mode access
authentication event fail action next-method
authentication host-mode multi-domain
authentication port-control auto
mab
no macro auto processing
spanning-tree portfast
spanning-tree bpduguard enable
end
FreeRADIUS User:
406c8f1e360f Cleartext-Password := "406c8f1e360f"
        Service-Type = "Framed-User",
        Tunnel-Type=13,
        Tunnel-Medium-Type = 6,
        Tunnel-Private-Group-ID:1 = 100
I have also enabled use_tunneled_reply = yes in the eap.conf file.
RADIUS Debug on C3750x
Mar 31 22:44:29.066: %AUTHMGR-5-START: Starting 'mab' for client (406c.8f1e.360f) on Interface Gi2/0/27 AuditSessionID 0A0A0A270000015109B77931
Mar 31 22:44:29.075: RADIUS/ENCODE(00000000):Orig. component type = Invalid
Mar 31 22:44:29.075: RADIUS(00000000): Config NAS IP: 10.10.10.39
Mar 31 22:44:29.075: RADIUS(00000000): sending
Mar 31 22:44:29.075: RADIUS(00000000): Send Access-Request to 10.10.10.235:1812 id 1645/230, len 261
Mar 31 22:44:29.083: RADIUS:  authenticator 99 83 11 D2 70 11 43 49 - CB 55 F2 39 D9 84 8B C0
Mar 31 22:44:29.083: RADIUS:  User-Name           [1]   14  "406c8f1e360f"
Mar 31 22:44:29.083: RADIUS:  User-Password       [2]   18  *
Mar 31 22:44:29.083: RADIUS:  Service-Type        [6]   6   Call Check                [10]
Mar 31 22:44:29.083: RADIUS:  Vendor, Cisco       [26]  31
Mar 31 22:44:29.083: RADIUS:   Cisco AVpair       [1]   25  "service-type=Call Check"
Mar 31 22:44:29.083: RADIUS:  Framed-MTU          [12]  6   1500
Mar 31 22:44:29.083: RADIUS:  Called-Station-Id   [30]  19  "28-94-0F-D2-9D-9B"
Mar 31 22:44:29.083: RADIUS:  Calling-Station-Id  [31]  19  "40-6C-8F-1E-36-0F"
Mar 31 22:44:29.083: RADIUS:  Message-Authenticato[80]  18
Mar 31 22:44:29.083: RADIUS:   AD 78 33 C9 12 3C A0 89 E9 74 66 E1 88 22 A1 E5            [ x3<tf"]
Mar 31 22:44:29.083: RADIUS:  EAP-Key-Name        [102] 2   *
Mar 31 22:44:29.083: RADIUS:  Vendor, Cisco       [26]  49
Mar 31 22:44:29.083: RADIUS:   Cisco AVpair       [1]   43  "audit-session-id=0A0A0A270000015109B77931"
Mar 31 22:44:29.083: RADIUS:  Vendor, Cisco       [26]  18
Mar 31 22:44:29.083: RADIUS:   Cisco AVpair       [1]   12  "method=mab"
Mar 31 22:44:29.083: RADIUS:  NAS-IP-Address      [4]   6   10.10.10.39
Mar 31 22:44:29.083: RADIUS:  NAS-Port            [5]   6   60000
Mar 31 22:44:29.083: RADIUS:  NAS-Port-Id         [87]  23  "GigabitEthernet2/0/27"
Mar 31 22:44:29.083: RADIUS:  NAS-Port-Type       [61]  6   Ethernet                  [15]
Mar 31 22:44:29.083: RADIUS(00000000): Sending a IPv4 Radius Packet
Mar 31 22:44:29.083: RADIUS(00000000): Started 5 sec timeout
Mar 31 22:44:29.100: RADIUS: Received from id 1645/230 10.10.10.235:1812, Access-Accept, len 44
Mar 31 22:44:29.100: RADIUS:  authenticator 69 67 B4 07 EF D8 73 EE - EA 23 A9 BA 92 5C A5 DE
Mar 31 22:44:29.100: RADIUS:  Service-Type        [6]   6   Framed                    [2]
Mar 31 22:44:29.100: RADIUS:  Tunnel-Type         [64]  6   00:VLAN                   [13]
Mar 31 22:44:29.100: RADIUS:  Tunnel-Medium-Type  [65]  6   00:ALL_802                [6]
Mar 31 22:44:29.100: RADIUS:  Tunnel-Private-Group[81]  6   01:"100"
Mar 31 22:44:29.100: RADIUS(00000000): Received from id 1645/230
Mar 31 22:44:29.108: %MAB-5-SUCCESS: Authentication successful for client (406c.8f1e.360f) on Interface Gi2/0/27 AuditSessionID 0A0A0A270000015109B77931
Mar 31 22:44:29.117: %AUTHMGR-5-FAIL: Authorization failed or unapplied for client (406c.8f1e.360f) on Interface Gi2/0/27 AuditSessionID 0A0A0A270000015109B77931
Mar 31 22:44:29.469: %LINK-3-UPDOWN: Interface GigabitEthernet2/0/27, changed state to up
Mar 31 22:44:30.475: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2/0/27, changed state to up
Any ideas on where this might be failing.
0 Replies 0
