Bookmark
Subscribe
3592
Ethernet Cable STP vs UTP
Rawa Salah
Dears
please which type of the ethernet cable Cat6  ( STP Vs UTP )  is better to use in the data center ?
daniel.dib
Level 7
Level 7
I have never seen STP used. Deploying STP is more complex due to the grounding required. Do you expect a lot of electromagnetic interference? Many of the cables in the datacenter will be fiber anway.
I would imagine that modern UTP has no problem to be deployed in a datacenter. Here is an interesting article:
http://www.cablinginstall.com/articles/print/volume-3/issue-9/crosstalk-feedback/editorial/shielded-and-unshielded-twisted-pair-cable-revisited.html
Daniel Dib
CCIE #37149
Please rate helpful posts.
Daniel Dib
CCIE #37149
CCDE #20160011
what do you mean by grounding ? need to ground the cable ?
there are more than 100 cable in one bandle , and the bandle near to the electrical cables , so its better to use stp by ur
opinion ?
Yes, you need to provide grounding at one or both ends of the cable as discussed here:
http://www.panduit.com/heiler/WhitePapers/UTP%20vs%20STP%20041307%20FINAL.pdf
How much power do you have in the electrical cables? How close are they?
Here is another paper also:
http://www.axis.com/files/whitepaper/wp_network_cables_47113_en_1203_lo.pdf
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Who installed that???
Any electrical or data cable installer knows full well data and electrical cables cannot be situated in the same cable cable tray.  Most DC standards I have read have power cables in an exclusive cable tray and bundled data cables are in another tray.
