3750x vrf: routing question
gavin han
I've following config:
int vlan5
ip add 10.10.1.1 255.255.255.0
int vlan4
ip vrf forwarding VPN
ip add 10.10.2.1 255.255.255.0
router eigrp 200
redistribute static
network 10.10.0.0 255.255.0.0
ip route 10.10.2.0 255.255.255.0 10.14.1.1
will above command show the "static" route that's being redistributed in the routing table or will it show directly connected vlan4 (that's in vrf VPN) in the routing table?
I believe it will show the static route that's being redistributed in the routing table but just wanted to be sure.
Nandan Mathure
If the static route is installed in the local routing table then yes you will see the static route being redistribute in global routing table.
VLAN4 is in vrf VPN and it is not part of eigrp, so what you think is right.
Nandan
Nandan Mathure
Nandan
