3825 router Power issue
charu.kamat
I have a peculiar issue with a router whering I get the message in the Show Environment as below.
sh environment out
Redundant Power System is not present.
SYS PS1 is present.
    Type: AC
AUX(-48V) PS1 is absent.
Fan  1 OK
Fan  2 OK
Fan  3 OK
Fan Speed Setting: Normal
Alert settings:
Intake temperature warning: Enabled, Threshold: 55
Core temperature warning: Enabled, Threshold: 70 (CPU: 95)
Board Temperature: Normal
Internal-ambient temperature = 22, Normal
CPU temperature = 37, Normal
Intake temperature = 22, Normal
Voltage 1(3300) is Normal, Current voltage = 3300 mV
Voltage 2(5150) is Normal, Current voltage = 5210 mV
Voltage 3(2500) is High/Low, Current voltage = 2168 mV
Voltage 4(1200) is Normal, Current voltage = 1215 mV
Show log message as below.
Apr 10 12:24:36.666 UTC: %SENSOR-3-VOLT_WARNING: Voltage monitor 3(2500) has exceeded voltage thresholds
Apr 10 12:25:16.666 UTC: %SENSOR-3-VOLT_WARNING: Voltage monitor 3(2500) has exceeded voltage thresholds
Apr 10 12:25:56.665 UTC: %SENSOR-3-VOLT_WARNING: Voltage monitor 3(2500) has exceeded voltage thresholds
Apr 10 12:26:36.664 UTC: %SENSOR-3-VOLT_WARNING: Voltage monitor 3(2500) has exceeded voltage thresholds
Apr 10 12:27:16.663 UTC: %SENSOR-3-VOLT_WARNING: Voltage monitor 3(2500) has exceeded voltage thresholds
Apr 10 12:27:56.662 UTC: %SENSOR-3-VOLT_WARNING: Voltage monitor 3(2500) has exceeded voltage thresholds
Apr 10 12:28:36.662 UTC: %SENSOR-3-VOLT_WARNING: Voltage monitor 3(2500) has exceeded voltage thresholds
Apr 10 12:29:16.661 UTC: %SENSOR-3-VOLT_WARNING: Voltage monitor 3(2500) has exceeded voltage thresholds
Apr 10 12:29:56.660 UTC: %SENSOR-3-VOLT_WARNING: Voltage monitor 3(2500) has exceeded voltage thresholds
Apr 10 12:30:36.659 UTC: %SENSOR-3-VOLT_WARNING: Voltage monitor 3(2500) has exceeded voltage thresholds
Apr 10 12:31:16.659 UTC: %SENSOR-3-VOLT_WARNING: Voltage monitor 3(2500) has exceeded voltage thresholds
Apr 10 12:31:56.658 UTC: %SENSOR-3-VOLT_WARNING: Voltage monitor 3(2500) has exceeded voltage thresholds
Apr 10 12:32:36.657 UTC: %SENSOR-3-VOLT_WARNING: Voltage monitor 3(2500) has exceeded voltage thresholds
Apr 10 12:33:16.656 UTC: %SENSOR-3-VOLT_WARNING: Voltage monitor 3(2500) has exceeded voltage thresholds
Appreciate a reply on this.
5 Replies 5
Steven Clinton
That usually means that it has the capability for a second power supply, but it's not installed
InayathUlla Sharieff
Hi charu,
No more furthershooting for this :-)
Straight away go ahead and raise the RMA to get the device replaced.
Inayath
*Plz rate the usefull posts.
Hi Steven/Inayathulla,
As per the logs the issue seems to be with the power. Would replacing the power supply do any good?
Steven Clinton
I do not see a hard fault in the data you have provided, I only see that the thresholds are being exceeded. I would have someone verify the power and compare it to another device connected to the same power source.
Hope that makes sense
Error Message    SENSOR-3-VOLT_WARNING: Voltage monitor "d"("d") has exceeded voltage
thresholds
Explanation One of the measured voltage test points indicates that voltage is out of normal range.
Explanation: Check Power Supplies or contact TAC
