3845 CEF enabled with throughput at process switched level
rugman66
I have a 3845 router as the GW running an NM-16ESW card with one GigE port being used as the trunk to the backbone c2960x switch. CEF is enabled globally on the 3845 and on the NM-16ESW GigE port. However the NM-16ESW GigE port input queue is dropping a very high amount of packets, and the throughput speed is an average of 9Mb/s. It should be in the 200Mb/s range when running CEF for the 3845 platform according to this Cisco doc.
https://community.cisco.com/t5/routing/process-switching-in-routers/td-p/1122323?attachment-id=83559
Would very much appreciate any SME suggestions on where to troubleshoot. I'll run and post any show command requested.
post the output of 'show interfaces x' of both connected GigabitEthernet ports...
Sure,
I swapped the 2960 back for the c4948 just fyi.
3845
englrn-hackshare-gw1-rack-10#sh interfaces gigabitEthernet 1/0
GigabitEthernet1/0 is up, line protocol is up
Hardware is Gigabit Ethernet, address is c471.fe4a.9b4b (bia c471.fe4a.9b4b)
Description: Trunk to 4948_left
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
output flow-control is off, input flow-control is off
0 pause input, 0 pause output
Full-duplex, 1000Mb/s
Last input 00:00:31, output never, output hang never
Last clearing of "show interface" counters 1d01h
Input queue: 0/100/1876447/0 (size/max/drops/flushes); Total output drops: 556
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 299000 bits/sec, 96 packets/sec
5 minute output rate 364000 bits/sec, 89 packets/sec
45626513 packets input, 3052682201 bytes, 0 no buffer
Received 48623 broadcasts (0 multicasts)
4071 input errors, 1 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
65195741 packets output, 725041682 bytes, 0 underruns
1 output errors, 0 collisions, 0 interface resets
2767 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
c4948
englrn-rack-10-4948-backbone#sh interfaces gigabitEthernet 1/48
GigabitEthernet1/48 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is 001d.a26e.c42f (bia 001d.a26e.c42f)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
Media-type configured as RJ45 connector
input flow-control is off, output flow-control is off
Last input 00:00:00, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 511000 bits/sec, 126 packets/sec
5 minute output rate 776000 bits/sec, 153 packets/sec
15926388707 packets input, 18471338162060 bytes, 0 no buffer
Received 58337552 broadcasts (49941775 multicast)
12175631128 packets output, 5931305547568 bytes, 0 underruns
Central CEF is enabled
englrn-hackshare-gw1-rack-10#sh cef state
CEF Status:
RP instance
common CEF enabled
IPv4 CEF Status:
CEF enabled/running
dCEF disabled/not running
CEF switching enabled/running
universal per-destination load sharing algorithm, id 7AD4FEAD
CEF shows enabled on the interface with this show command
englrn-hackshare-gw1-rack-10#sh ip cef gigabitEthernet 1/0 detail
IPv4 CEF is enabled and running
VRF Default
169 prefixes (169/0 fwd/non-fwd)
Table id 0x0
Database epoch: 0 (169 entries at this epoch)
CEF Does not show in the “show interfaces gigabitEthernet 1/0” command
  Last input 00:00:40, output never, output hang never
  Last clearing of "show interface" counters 2d00h
  Input queue: 0/100/3718489/0 (size/max/drops/flushes); Total output drops: 966
  5 minute input rate 265000 bits/sec, 109 packets/sec
  5 minute output rate 568000 bits/sec, 115 packets/sec
     85716641 packets input, 3375351072 bytes, 0 no buffer
     Received 79867 broadcasts (0 multicasts)
     124138662 packets output, 3665235943 bytes, 0 underruns
Also the gigabitEthernet 1/0 interface is not listed when running the
“show ip cef” command and is exclusively process switching. Note the
output below
englrn-hackshare-gw1-rack-10#sh interfaces gigabitEthernet 1/0 stats
GigabitEthernet1/0
          Switching path    Pkts In   Chars In   Pkts Out  Chars Out
               Processor   85740948 3379504877  124168172 3690622687
             Route cache          0          0          0          0
                   Total   85740948 3379504877  124168172 3690622687
