09-07-2018 10:26 AM - edited 03-08-2019 04:06 PM
So I have a pair of lab 4510 switches joined VSS.
The standby SUPs in both switches are showing standby-cold RPR mode. Any ideas?
09-07-2018 11:05 AM
Is this a quad sup design?
What is the output of "sh redun"?
Also, can you post the VSS config?
09-08-2018 07:42 AM
Yes it is. Both WS-C4510R+E have dual SUPs.
See SHOW REdun, module and running configs below. Secondary 4510 has identical VSS configs, exdluding virtual numbers, links, and so forth.
sh redundancy
Redundant System Information :
Available system uptime = 17 hours, 23 minutes
Switchovers system experienced = 0
Standby failures = 0
Last switchover reason = none
Hardware Mode = Duplex
Configured Redundancy Mode = Stateful Switchover
Operating Redundancy Mode = Stateful Switchover
Maintenance Mode = Disabled
Communications = Up
Current Processor Information :
Active Location = slot 1/5
Current Software state = ACTIVE
Uptime in current state = 17 hours, 20 minutes
Image Version = Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.08.06.E RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Thu 05-Apr-18 06:32 by prod
BOOT = bootflash:cat4500e-universalk9.SPA.03.08.06.E.152-4.E6.bin,12;
Configuration register = 0x2102
Peer Processor Information :
Standby Location = slot 2/5
Current Software state = STANDBY HOT
Uptime in current state = 17 hours, 19 minutes
sh module
Switch Number: 1 Role: Virtual Switch Active
Chassis Type : WS-C4510R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model Serial No.
1 48 1000BaseX SFP WS-X4748-SFP-E CAT2141L31Y
2 48 10/100/1000BaseT UPOE E Series WS-X4748-UPOE+E CAT2142L4LU
3 48 10/100/1000BaseT UPOE E Series WS-X4748-UPOE+E CAT2142L7A4
4 48 10/100/1000BaseT UPOE E Series WS-X4748-UPOE+E CAT2140L7NU
5 4 Sup 7-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP7-E CAT2140L945
6 4 Sup 7-E 10GE (SFP+), 1000BaseX (SFP)
7 48 10/100/1000BaseT UPOE E Series WS-X4748-UPOE+E CAT2140L7M5
8 48 10/100/1000BaseT UPOE E Series WS-X4748-UPOE+E CAT2140L7VN
9 48 10/100/1000BaseT UPOE E Series WS-X4748-UPOE+E CAT2140L7Y0
10 12 10GE SFP+ WS-X4712-SFP+E CAT2140L75H
M MAC addresses Hw Fw Sw Status
1 380e.4de4.1470 to 380e.4de4.149f 1.0 Ok
2 707d.b9b9.ce7c to 707d.b9b9.ceab 1.1 Ok
3 6cb2.ae25.fcb8 to 6cb2.ae25.fce7 1.1 Ok
4 380e.4d67.43a8 to 380e.4d67.43d7 1.1 Ok
5 380e.4d95.6f00 to 380e.4d95.6f03 3.0 15.0(1r)SG10 03.08.06.E Ok
6 380e.4d95.6f04 to 380e.4d95.6f07 Provision
7 380e.4d67.43d8 to 380e.4d67.4407 1.1 Ok
8 6cb2.ae25.994c to 6cb2.ae25.997b 1.1 Ok
9 6cb2.ae25.a5f4 to 6cb2.ae25.a623 1.1 Ok
10 6cb2.ae25.5cb0 to 6cb2.ae25.5cbb 2.0 Ok
Mod Redundancy role Operating mode Redundancy status
5 Active Supervisor SSO Active
6 In-Chassis Standby RPR Standby cold
Switch Number: 2 Role: Virtual Switch Standby
1 48 1000BaseX SFP WS-X4748-SFP-E CAT2137L25U
2 48 10/100/1000BaseT UPOE E Series WS-X4748-UPOE+E CAT2142L75S
3 48 10/100/1000BaseT UPOE E Series WS-X4748-UPOE+E CAT2142L718
4 48 10/100/1000BaseT UPOE E Series WS-X4748-UPOE+E CAT2142L6ZB
5 4 Sup 7-E 10GE (SFP+), 1000BaseX (SFP) WS-X45-SUP7-E CAT2140L94L
7 48 10/100/1000BaseT UPOE E Series WS-X4748-UPOE+E CAT2142L6ZQ
8 48 10/100/1000BaseT UPOE E Series WS-X4748-UPOE+E CAT2142L4JJ
9 48 10/100/1000BaseT UPOE E Series WS-X4748-UPOE+E CAT2142L4PM
10 12 10GE SFP+ WS-X4712-SFP+E CAT2140L77E
1 707d.b95d.62f0 to 707d.b95d.631f 1.0 Ok
2 380e.4dfc.c420 to 380e.4dfc.c44f 1.1 Ok
3 380e.4d53.0d8c to 380e.4d53.0dbb 1.1 Ok
4 6cb2.ae87.1990 to 6cb2.ae87.19bf 1.1 Ok
5 380e.4d95.8380 to 380e.4d95.8383 3.0 15.0(1r)SG10 03.08.06.E Ok
6 380e.4d95.8384 to 380e.4d95.8387 Provision
7 6cb2.ae3c.1e7c to 6cb2.ae3c.1eab 1.1 Ok
8 380e.4de4.26d0 to 380e.4de4.26ff 1.1 Ok
9 380e.4de4.22b0 to 380e.4de4.22df 1.1 Ok
10 6cb2.ae25.5050 to 6cb2.ae25.505b 2.0 Ok
5 Standby Supervisor SSO Standby hot
switch virtual domain 1
switch mode virtual
switch 1 priority 110
mac-address use-virtual
interface TenGigabitEthernet1/5/1
switchport mode trunk
switchport nonegotiate
no lldp transmit
no lldp receive
no cdp enable
channel-group 100 mode on
service-policy output VSL-Queuing-Policy
interface TenGigabitEthernet1/6/1
no lldp transmit
no lldp receive
no cdp enable
interface TenGigabitEthernet2/5/1
no lldp transmit
no lldp receive
no cdp enable
channel-group 101 mode on
interface TenGigabitEthernet2/6/1
no lldp transmit
no lldp receive
no cdp enable
09-08-2018 12:25 PM
I think this is ok and it is normal. Sup-5 in each chassis is in SSO mode and sup-6 is RPR.
The config is also correct.
09-08-2018 01:15 PM
09-08-2018 01:49 PM
I have never configured a quad sup VSS, and I am not sure if you can console to the standby but as far SSO vs RPR the behavior seems to be correct.
09-08-2018 07:32 PM
09-07-2018 05:43 PM
09-08-2018 07:35 PM
